Old 04-01-2010, 12:20 PM   #1
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
engine install (and getting the truck back on the road)
I have my new to me 86' SWB, that I did some trading for and am in the process of getting it back on the road....
it would not run when i got it, and it was about 1/2 a can low on compression..
I am in the middle of installing another "mystery" engine in the truck, and have been tearing it down today for inspection and to reseal and replace the gaskets on it.....
I already have an eldebrock 600cfm carb, and performer intake and headers that came with the truck.
while tearing the "new" engine down, thats going in the truck, I have found a few things....
it has comp cam roller tip rocker arms stock ratio
world products s/r torquer cylinder heads
been bored 30 over and has flat tops with 4 vale reliefs.
has a pete jackson gear drive.. don't know which one...cam gear is stamped "PJ 92 (hope it is one of the quiet ones)
has a crane compucam 2040 camshaft
has a windage tray and a melling HV oil pump....
plan on taking a few pics today to add to this thread.... I have to read a little more about the cam, but I hope it will work well with the other parts on the engine......
opinions?
tommie is offline   Reply With Quote
Old 04-01-2010, 12:41 PM   #2
Bubba's79
Bubba's79's Avatar
Re: engine install (and getting the truck back on the road)
Sounds like alot of fun when you stab that back in . What was the piston to wall clearance.
1979 C10 SWB 390CI/350 3.73GEARS
Horsepower sells motors Torque wins races!
http://67-72chevytrucks.com/vboard/s...d.php?t=397626
Bubba's79 is offline   Reply With Quote
Old 04-01-2010, 03:35 PM   #3
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
have not checked the piston to wall clearance, you can still see the cross hatches in the cylinder walls...
this is basically just a reseal the new engine going in...the previous engine owner got rid of it because it was leaking oil.....
Old 04-01-2010, 04:39 PM   #4
Bubba's79
Bubba's79's Avatar
just wondering pistons dont rock or move at all do they
Old 04-01-2010, 05:03 PM   #5
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
no they feel fine....
