Old 04-01-2010, 02:30 PM   #1
boucher racing
boucher racing's Avatar
Question help - inline 250 oil pan removal tips / tricks?? its stuck!
Hello,
I am building a turbo system for my inline 250. When dropping the oil pan to tap it for a oil return line, I got stuck. I removed all of the bolts and the trans shield and it seems that the oil pan needs about another 1" of clearance to drop below the flex-plate. How do I go about getting it to slide all the way out?
Thanks,
Boucher
Build Threads: "JED" 66 GMC C1000
http://inliners.org/ubbthreads/ubbth...1857#Post61857
"Cropwell" 66 C10
http://67-72chevytrucks.com/vboard/s...d.php?t=587639
boucher racing is offline   Reply With Quote
Old 04-01-2010, 06:15 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: help - inline 250 oil pan removal tips / tricks?? its stuck!
Unbolt the engine mounts, jack the engine up and stick blocks of wood between the mounts and frame stands.
Old 04-01-2010, 06:17 PM   #3
boucher racing
Thanks, I'll give it a try.
"Cropwell" 66 C10
Old 04-01-2010, 07:22 PM   #4
Togart
Togart's Avatar
A turbo 250.....that sounds interesting. Details?
Togart
Togart is offline   Reply With Quote
Old 04-02-2010, 12:01 AM   #5
boucher racing
Well, I put a piece of wood under the front of the oil pan and jacked it up until a 2x4 or 1.5" would fit between the engine and the mounts. Lowered the jack and the pan slid right out!
The Turbo project is going well. I think I will be able to fire it this weekend. The last thing to do is run the oil return to the pap, fab the downpipe to direct the exhaust out and pipe the bonnet. I am using a blow thru modded Holley 2300, modded Holley FPR to boost reference, a Grand National T3 turbo, a custom fab up-pipe routed under the frame. It has come together quite well with a ton of mock-up. I am sure there will need to be alot of tuning once I get it running. Its been a real fun project and now if I can just get to run!
"Cropwell" 66 C10
Old 04-02-2010, 08:11 AM   #6
Togart
Togart's Avatar
Cool...sounds like a neat project. You'll have to let us know how it works out
Togart
