Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-01-2010, 03:05 PM   #1
will scratch
will scratch's Avatar
rack and pinion
I'm wanting to get information and pics on how to do rack and pinion steering setup. Would like to go with manual to do away with the pump. How bout you guys that have done it give us some pros and cons, work involved, parts required, etc. My goal would be focused mostly on the weight savings off the front, so is it worth doing and what are the real benifts. Thanks.
79 Blazer 2wd; flip kit drop spindles and springs.
will scratch is offline   Reply With Quote
Old 04-01-2010, 10:38 PM   #2
djracer
djracer's Avatar
Re: rack and pinion
I have a mustang II fatman fabrication bolt in kit. It has a manual rack. It saves a ton of weight.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-01-2010, 11:05 PM   #3
midevil1
ShortBus KingPin
midevil1's Avatar
Re: rack and pinion
I made my own with a 79 to 93 foxbody manual rack. UPR bump stop tie rod's and extenders. I used 1/8th" plate for gusset's and 1 1/2" pipe clamps for mounts. You have to cutoff the original mounts for it to fit to the crossmember. Truck steers like a dream and the amount of rotations on the wheel are atleast half of original. Was quite simple to do and might've taken 8 hours total to finish. I have one pic and will take somemore of the finished product. It was worth it a 100 times over......
67 shortstep prosteet. 505 BBC, FULL BILLET TH350, Owner built EVERYTHING.... (My RIDE)
2008 GMC Yukon DENALI, 425 AWHP, 5700LBS, 12.40's at 109mph. (Her RIDE)
2006 Kawasaki Brute Force, 916cc, 80 shot, 6.20's at 111 mph. (Her RIDE)
midevil1 is offline   Reply With Quote
Old 04-01-2010, 11:27 PM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: rack and pinion
any change on the turning circle?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-02-2010, 08:15 AM   #5
Wild83C10
Wild83C10's Avatar
Re: rack and pinion
You can stick with a power rack, just buy an aluminum rack.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 04-02-2010, 09:13 AM   #6
midevil1
ShortBus KingPin
midevil1's Avatar
Re: rack and pinion
Turning radius is better than stock.
Old 04-02-2010, 03:25 PM   #7
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Re: rack and pinion
Anyone have a link from a vendor for one of these kits?
Would love to have this on my truck!!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 04-02-2010, 04:20 PM   #8
midevil1
ShortBus KingPin
midevil1's Avatar
Re: rack and pinion
Custom Classic Trucks and Classic Trucks have tons of AD'S for vendors with these types of kits. Fatman Fabrication is one of the better known vendors.
I perfer to make everything myself. Thats just me. My truck is one loooooong conversation piece. If you have the ability and the means to do it yourself. It is not that bad of a project. I bet I have less than a 1/4 the cost of one of the aftermarket kits in my steering and eveything is stainless or billet.
Old 04-03-2010, 12:03 AM   #9
will scratch
Re: rack and pinion
found this
http://www.customclassictrucks.com/t.../photo_28.html
Interesting cross member here, some fatman stuff. but i sure like the idea of pipe clamps and a manual rack (1/4 cost) would like to see more. what did you use from rack to spindle couldn't tell from your pic.
thanks all for the feed back.
Last edited by will scratch; 04-03-2010 at 12:12 AM. Reason: went back and read upr ends and extentions whats that??
Old 04-03-2010, 11:55 PM   #10
midevil1
ShortBus KingPin
midevil1's Avatar
Re: rack and pinion
I used these spherical tie rod ends from UPR and their bumpsteer kit.
Brakes are from a 72 Impala SS and I crossdrilled them for shorter stopping distances.
Old 04-04-2010, 12:47 PM   #11
team39763
Re: rack and pinion
Midevil1, could you show us another pic of how you mounted the rack? I'm seriously considering this as my next mod for weight reduction.
1982 Silverado - SBE, cleaned up GM heads, small cam, TH350, 850 Demon, 4.56 gears, and caltracs.
Best time so far 11.8@XXXMPH
team39763 is offline   Reply With Quote
Old 04-04-2010, 06:17 PM   #12
69trk
69trk's Avatar
Re: rack and pinion
I'm also very interested...
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 04-04-2010, 10:22 PM   #13
midevil1
ShortBus KingPin
midevil1's Avatar
Re: rack and pinion
Got a local member coming by to take pics for the same thing. I will get as many pics as I can to post on here.
I really need to start a build thread, HUH? Most of my build pics are stuck on my crashed laptop, otherwise I would show you guys all my homemade parts......
Old 04-06-2010, 01:04 PM   #14
C20-67_N_MO
Re: rack and pinion
You have any links to these guys?
And if I had the parts list I would gladly piece it together myself!
Old 06-30-2010, 12:40 PM   #15
68GMCCustom
Re: rack and pinion
any updates on the pics of the rack and pinion setup? I am planning on doing this... rather then rebuild the OEM complete steering system.
Kurt -
Old 06-30-2010, 04:17 PM   #16
djracer
djracer's Avatar
Re: rack and pinion
You can buy a cheap usb reader for your old laptop hard drive so you can get your stuff off it if the drive itself isn't bad.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 06-30-2010, 10:38 PM   #17
midevil1
ShortBus KingPin
midevil1's Avatar
Re: rack and pinion
Power supply is bad. SORRY guys I forgot about this thread all together. Taking it to get all the info retrieved. Let me see what I have for pics on this laptop.....
Old 06-30-2010, 10:51 PM   #18
midevil1
ShortBus KingPin
midevil1's Avatar
Re: rack and pinion
I added lower gussets to the bottom of the u-bolts, but dont have any pics of the final product. I Used a crome-moly oil pump driveshaft out of a SBF for the side to side bracing. I will get somemore....
Old 07-01-2010, 04:56 AM   #19
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: rack and pinion
Mine...'62
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 07-01-2010, 11:36 AM   #20
C20-67_N_MO
Re: rack and pinion
I sooo want a Rack and pinion setup.
If I do the conversation, what parts should I look for in the junk yard or pick-n-pull yards to piece this system together?
Thanks guys!
Old 07-01-2010, 03:50 PM   #21
midevil1
ShortBus KingPin
midevil1's Avatar
Re: rack and pinion
No need to go to the junkyard. You can get everything new for relatively cheap. Foxbody mustang manual or power rack can be had at any local parts house. Tierods and extensions can be bought from UPR products or ebay. Supplies to build Mounts can be bought from local stores.
Old 07-01-2010, 06:16 PM   #22
68GMCCustom
Re: rack and pinion
I was wondering....would it be possible to use the original mounts on the rack by welding some like 1-1.25" heavy wall DOM tubing to the OEM crossmember...with grade8 bolts straight thru the rack mount into the tubes with a lockwasher and a nut on the inside of the crossmember. Would be as strong as the original rack mount?
and I've heard of using a t-bird rack over the Mustangs....whats the size difference?
Kurt -
Old 07-01-2010, 07:28 PM   #23
C20-67_N_MO
Re: rack and pinion
Any idea what year to ask the parts store for one of these racks?
And what about Tierod ends and extensions? From what vehicle would they fit the 1967-72 Chevy Trucks?
Thanks.
Old 07-01-2010, 09:36 PM   #24
midevil1
ShortBus KingPin
midevil1's Avatar
Re: rack and pinion
You will have to channel the stock crossmember to use the original mounts. It will stick out to far and too low to fit to the spindle mounts. The way I did it came from the way that the Prostock cars mount theirs to the crossmembers. I took a 1.5 tube and smacked it with a hammer in my mounts and it didnt budge.
T-birds are the same rack up to 1988. They were then changed to the sn-95 chassis. The rack is wider on the 89 and up T-birds. Factory didnt offer a manual rack, so aftermarket is where you would have to get one. $$$$$
Old 07-01-2010, 09:56 PM   #25
68GMCCustom
Re: rack and pinion
my truck will be an occasional cruiser and I'll drive it to the track...so I'll be going with a power rack.
Kurt -
