Old 04-01-2010, 03:18 PM   #1
acl
acl's Avatar
Rusty Gas tank
started driving a truck that has been parked a few years. Fuel filter is plugging up quickly with rust. What is the best way to clean out tank? checked with radiator shop and they charge $150.00 to dip. That what a new one cost. Any help please? Gary
acl is offline   Reply With Quote
Old 04-01-2010, 04:10 PM   #2
cdowns
cdowns's Avatar
Re: Rusty Gas tank
with the tank out and stripped and empty i'd start by using a pressure washer to blast around the inside of the tank to get all the loose stuff i could dislodge// the next step would be getting some pool cleaner stuff(muriatic acid) letting it soak a couple of hours// then rince with the pressure washer again after that i'd use an air hose or vaccume to blow air thru it to remove the moisture
Old 04-01-2010, 06:03 PM   #3
epashhans
epashhans's Avatar
Re: Rusty Gas tank
I can't remember if it was on this forum or somewhere else, but someone had said draino works good. Pretty cheap too. Wish I could remember where I saw that...
'67 C-10 Shorty - 454, 5spd, and speed holes!
epashhans is offline   Reply With Quote
Old 04-01-2010, 06:10 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Rusty Gas tank
Like cdowns said, I use Muriatic acid. It is cheap at any hardware store and it will sure enough get the crud out. Don't breath the fumes.
Old 04-01-2010, 09:22 PM   #5
brans72
Re: Rusty Gas tank
How much Muriatic acid would you suggest using in this process?
brans72 is offline   Reply With Quote
Old 04-01-2010, 09:42 PM   #6
Tx Firefighter
Re: Rusty Gas tank
I usually use about a quart of acid and a few gallons of water. Cover openings with duct tape and slosh around. Repeat a few times until you're just getting clean water out.
Flush thoroughly with water hose.
Be careful !
Old 04-01-2010, 10:12 PM   #7
Chevydude56
Chevydude56's Avatar
Re: Rusty Gas tank
I have used acid also with good results. I have also put a piece of chain in the tank and slosh it around it helps to "scrub" the inside and take off the loose rust . my $.02
1967 Suburban 292 3spd
1964 Chevy II wagon
1971 Monte Carlo 402BB
1964 Cadillac series 62 2dr
1964 Bonneville 2dr/ht
1967 GTO
1978 Chevy Van 30
1989 R30 Crew Dually Bonus Cab
Chevydude56 is offline   Reply With Quote
Old 04-01-2010, 10:29 PM   #8
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Rusty Gas tank
Bummer you're not closer as I would give you mine which is in great shape. Suggestions about are very good one.
Good luck.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
