Old 04-01-2010, 05:54 PM   #1
MT300RUM
MT300RUM's Avatar
Single or Double??
I should probably know, But i don't, Ive owned my 72 K5 for 5 years and it's only had the one top, so how can you tell if it is a single wall or double wall top? i never even knew there were different tops till i joined this site,
MT300RUM is offline   Reply With Quote
Old 04-01-2010, 07:14 PM   #2
SeventyOne
Re: Single or Double??
Easiest way to tell is to look at the bolts that hold the top onto the bedsides.
If the bolts go down into the bedside you have a single wall.
If the bolts go up into the top from under the bed railing you have a double wall.
Another way to tell is if you have lights mounted to your top on near the rear side window.
If you have a 72 and it's the stock top, it's likely a single wall.
SeventyOne is offline   Reply With Quote
Old 04-01-2010, 07:37 PM   #3
clos69
Its Topless Season!!!!
clos69's Avatar
Here are some pics for comparison
Double wall
Single wall
-Carlos-
The of America
1967 SWB Custom C-10 (Celeste)
Join the Patina Club
clos69 is offline   Reply With Quote
Old 04-01-2010, 08:53 PM   #4
MT300RUM
MT300RUM's Avatar
Thanks you guys are great, now if anybody asks i can tell them i have a single wall top, and act like i know something, Thanks again for the info..
p.s clos69, what are the long stainless pieces laying in the back on the lower pic? i have a couple of these lying around myself
Old 04-01-2010, 09:08 PM   #5
Tbruz
Not trying to hijack the thread but................is one type better than the other? Quieter??
Thanks,
tbruz
Tbruz is offline   Reply With Quote
Old 04-01-2010, 09:11 PM   #6
71swb4x4
71swb4x4's Avatar
Thanks,
tbruz
A lot of people like the single wall best because the bolts go down into the bed sides. If you have interior side panels in the cargo area you can install and remove the top without removing your side panels.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-01-2010, 09:21 PM   #7
MT300RUM
MT300RUM's Avatar
Thanks,
tbruz
Hijack away bud, my ? was already answered
Old 04-01-2010, 09:52 PM   #8
SeventyOne
People also argue that single walls are noticeably lighter.......I doubt that based on their construction but I've never lifted a single off a truck before.
Quieter.....haven't heard that comparison before but I would think a dbl would be quieter if at all.
Old 04-01-2010, 09:57 PM   #9
litebulblsc
litebulblsc's Avatar
If I didn't have side panels or never planned to take the top off, I would go with a double wall, just because I think it looks better on the inside.
litebulblsc is offline   Reply With Quote
Old 04-01-2010, 10:36 PM   #10
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Actually, the easiest way to tell the difference is if it has dome lights.
No Dome lights = double wall
dome lights = singlewall
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-02-2010, 01:14 AM   #11
lks dcvn
lks dcvn's Avatar
Or the plug for the lights behind the driver seat if you can't see the lights in some angles...
lks dcvn is offline   Reply With Quote
Old 04-02-2010, 09:48 AM   #12
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Im not trying to be funny here, but mine was quietest with the top off.
Tom Vogel is offline   Reply With Quote
Old 04-06-2010, 07:49 AM   #13
clos69
clos69's Avatar
Those are my carpet edge strips
-Carlos-
The of America
Old 04-08-2010, 10:11 PM   #14
EFI70Blazer
Active Member
EFI70Blazer's Avatar
The biggest issue i have seen with double wall tops is the warpage. Single wall tops don't seem to warp as bad if at all.
Mike T.
Oregon
70 GMC Jimmy 4x4
70 Camaro LS1 plans in the works
71 RS/SS Camaro numbers matching
86 Chevy Silverado SWB 4x4 (454 merlin heads, 3/4 running gear upgrade, Detroit lockers front and rear)
EFI70Blazer is offline   Reply With Quote
