Old 04-02-2010, 12:10 AM   #1
corcor67
Disc Brake Swap...again
I'm sure its been asked on here a thousands of times before me, but I can't seem to find the parts needed to make it happen. I have a 67 c-20 and want to put some discs up front. I would like to run some aftermarket drop spindles, but hoping to come up with the rest from a junk yard or local parts truck. If I remember correctly the years to look for is 73-87 (correct me if I'm wrong). And what, ball joints, tie rod ends, rotors if there good, calipers...what am I missing?
corcor67 is offline   Reply With Quote
Old 04-02-2010, 01:40 AM   #2
Jeffs70
Jeffs70's Avatar
Re: Disc Brake Swap...again
if it was me I would purchase the whole front section with the cross member and all and just bolt it all up onto my truck instead of having to put it all back together in steps and I believe your correct on the years that are the same setup
Jeffs70 is offline   Reply With Quote
Old 04-02-2010, 01:45 AM   #3
corcor67
It'll all bolt up with factory holes, or would that include some hole drilling? No problem drilling holes just wanting to know what kind of work id be in for.
Old 04-02-2010, 02:01 AM   #4
Jeffs70
Jeffs70's Avatar
yep its all bolt on if you unbolt the cross member of 3 bolts on each side of the frame then you should be good to go on that. shouldnt need to drill at all
Old 04-02-2010, 02:08 AM   #5
corcor67
Easy enough...thanks
Old 04-02-2010, 09:09 AM   #6
my67c20
Use caution and be sure to make sure you know exactly what year the assembly came from. This will only help if you intend on doing any balljoint replacements. And if you buy it from someone make sure they tell you as well. Trust me 3 months and i think i might actually know what it is that i am working with.
my67c20 is offline   Reply With Quote
Old 04-02-2010, 10:24 AM   #7
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
id buy a conversion drop spindle
then go junkyard and get rotors/calipers
and buy new hoses (40 year old ones arent gonna be good enough)
new pads bearings and seals and a new Mc/prop. valve and get rearend stuff from junkyard
John
1999 Toyota Tacoma 4x4
Old 04-02-2010, 10:37 AM   #8
junkman
another option would be going with a 88-98 spindle setup. you could use your control arms, just need the 88-98 ball joints, and tie rods. Then you could have your choice of 5 or 6 lug rotors. I see those drop spindles for sale used pretty frequently on some of the other boards.
junkman is offline   Reply With Quote
Old 04-02-2010, 11:03 AM   #9
1968longbed
i have a 68, six lug. i bought an complete 85 clip. could i just change the ball joints and install the spindles?
1968longbed is offline   Reply With Quote
Old 04-02-2010, 12:20 PM   #10
marcsRX
68 C10 SWB
marcsRX's Avatar
I am in a similar position. I have a 68 that i want to put disks on. I have a 72 doner that i'd like to pull the parts from. Will a 72 to 68 transplant work?
"How much physical pain do you go through on a daily basis that you can directly attribute to your lack of intelligence?" -R0bman
marcsRX is offline   Reply With Quote
Old 04-02-2010, 01:27 PM   #11
michael bustamante
michael bustamante's Avatar
I just did this on my 67, installed 72 5 lug disks, I swapped over the control arms and hub assy no problem.
now for both you and corcor (who started the thread), dont forget your brakes! you'll have to swap over to the newer brake lines. and your steering rack assy will have to swapped over as well. 67-70 front end steering components will not work with the disk brake set up.
corcor, are you converting to half ton? you didnt mention if you were or not
1967custom
michael bustamante is offline   Reply With Quote
Old 04-06-2010, 03:42 PM   #12
corcor67
Wouldn't mind going 5 lug to increase rim options, but don't think I will. What's involved in swapping rear to 5?
Old 04-06-2010, 04:00 PM   #13
michael bustamante
you could either order 5 lug axles from ece or find a 71 72 rear end with coil spring. I doing the axle swap from a 72 and now the rear lines up with the front end just fine. if you go with the ece axle swap, youll notice the front end is now wider than the rear.
1967custom
