Old 04-02-2010, 01:21 AM   #1
cb1965
cb1965's Avatar
brake booster/mc for my brake swap!!
Hi guys,
i need some info on brake boosters. im currently gathering parts for my power brake swap. i have a '65 c20 that i got from an uncle. i have a crossmember from a '75(complete). will any booster/mc from 73-87 work or does it have to be the same as the cmember?any info is greatly appreciated. thanks
cb1965 is offline   Reply With Quote
Old 04-02-2010, 01:44 AM   #2
Captainfab
60-66 Nut
Re: brake booster/mc for my brake swap!!
Welcome to the forum
You can use the booster and master with the brackets from a '73-'87. You'll just have to drill some holes to bolt it up. If you don't already have the booster, you might take a look at the booster brackets that I make and sell. They are 100% bolt on....no holes to drill and worry about hitting something on the other side. The links are in my sig below.
Old 04-02-2010, 09:36 AM   #3
DPowers
DPowers's Avatar
Welcome as well-
CaptainFab does great work by the way.
DPowers is offline   Reply With Quote
Old 04-02-2010, 04:48 PM   #4
cb1965
cb1965's Avatar
thanks for the welcome,
ok sorry if i sound redundant i just need to get it all down before i start tearing in to my truck.
booster/mc from any 73-87.
is there any difference between a booster with a cast iron resirvoir and one with the plastic one? does it matter?
what has to be done to the shaft or rod? if anything.
prop valve 73-87 also?
what size brake line is needed? fittings?
what tools?
this is my first project so i want to have all the info possible.
again thank you guys for the help.
Old 04-02-2010, 06:03 PM   #5
Russ65C10
Russ65C10's Avatar
I used the booster and master cyclinder off of the donner truck when I switched to disc on my 65. I used the exsiting holes to mount it using the 4 bottom holes on mounting bracket. That was 12 years about 40K miles ago, haven't had any problems.
You'll need to run new lines for your front brakes and new lines for your rear's back to the hose that links between your rear axle and frame. I used washers and "thin" nut to mate up the rubber front hoses with the new hard lines using holes in the frame located between the front shocks and front suspension.
You will have to lengthen the rod that goes from your brake pedal to the master.
Russ65C10 is offline   Reply With Quote
Old 04-03-2010, 12:00 AM   #6
DPowers
DPowers's Avatar
Check here-
http://67-72chevytrucks.com/vboard/s...ght=disc+brake
