Old 04-02-2010, 07:56 AM   #1
Kevin McPherson
Kevin McPherson's Avatar
tie rod problem
I would like to know where I could find a new or used tie rod for my 72 blazer. The reason I need a new one is a previous owner found a stump or rock and bent it bad. is it possoble to straighten it without creating more damage??
Kevin McPherson is offline   Reply With Quote
Old 04-02-2010, 01:50 PM   #2
OrrieG
OrrieG's Avatar
Re: tie rod problem
I straightened mine (former owner problem too) with a Prota Power and creative blocking to the front crossmember and axle. Make sure you measure the track width before so you can adjust it back in when the rod is straight.
OrrieG is offline   Reply With Quote
Old 04-02-2010, 02:29 PM   #3
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: tie rod problem
They are hollow, so if its dented bad, you might be better off replacing it or making a new one.
51 .750 long
3/4 - 16 RH on the pass side
3/4 - 16 LH on the driver side
1 RH jam nut
1 LH jam nut
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
