Haven't had a lot of time to work on my truck but here is the latest...
http://s804.photobucket.com/albums/y...ild/?start=all Last edited by robgrin; 05-22-2010 at 03:11 PM. |
Re: pictures
![]() If you look near your picture (under or beside it depending on the view) you'll see the options shown here. Click on the IMG Code line and it should copy, otherwise, right click and copy then paste that in the message and, viola! ![]() ![]()
"just as the Son of man did not come to be served, but to serve, and to give His life as a ransom for many." Matthew 20:28 Classic Truck Shop |
Re: pictures
what I do is email my picts to myself! this shrinks them down. then I save them from my e-mail and use thoughs picts to add to this site! works well, can be a bit time consuming, but whats the rush anyway! hope this helps
Re: updated pictures
Thanks for the tips on posting pictures. This is the day i picked up the truck.
![]() Start of tear down ![]() Down to frame ![]() On the rear end i boxed and c notched the frame, put in a four link with a comaro rear end ![]() ![]() ![]() Installed an aluminum feul tank in the rear ![]() The day i picked up motor from engine builder. It's Just a 350 four bolt main with an xe 262 h comp cam, fueler 194 heads, Edlebrock performer intake with a 600 cfm carb. ![]() This is the day I picked up the trans from the tanny builder. It's a turbo 350 thats been upgraded with high performance parts,shift kit, and a 2500 stall converter. ![]() |
Re: update pictures continue
In the front I went with a Mustang 2 IFS- Boxed and c noched the frame, HEIDTS cross member,Tubular A arms, Disc brakes, 2" dropped spindles, Power steering rack
![]() ![]() ![]() ![]() Insalled a power brake unit with a corvette style 1 1/8 bore master cylinder,7" dual diaphragm booster, pv4 proportioning valve, front and rear rpv2 residual valves, and braided lines all four corners ![]() Comlete chassie ![]() ![]() |
Starting on the body work know;
Patching holes in doors ![]() ![]() ![]() ![]() Shaved the fuel fill hole ![]() ![]() ![]() Replaced rocker panel ![]() ![]() ![]() |
working dents out oround head lights
![]() ![]() Front clip assembled ![]() That's what I have done to this point. I stll want to put in an access panel in floor for the battery, Shave all the holes in the fire wall, And straighten out the bed side panels, For wheels and tires I think I want to go with 18x8.5 in the front and 20x10 in the rear. I really like the ( Eagle alloy 225 series ). For color maybe Turqoise. |
Re: pictures
Looking good so far! Very nice job on the welds...they yours or did you farm that part out to a friend/pro?
CLASSIX Truck Club
Re: pictures
Looking real good. Whats your plans for that grille?
Re: pictures
Thanks; I wish I could say I did all the welding. You can see in the pictures I had the cross members, hats and box plates mocked up but decided to have a pro weld them in. I did weld the motor mounts and made the trans cross member. As for the grill I think I'm going to have it chromed because I hear the re production grills don't fit.
Re: pictures
Very good start. Look FWD to watching the build!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe ![]() |
Re: pictures
#13 |
Re: pictures
Nice truck! Like the picture and the detail you are putting into your truck build. Keep the pictures coming.
FAT MIKE My 59 http://67-72chevytrucks.com/vboard/s...d.php?t=400201 My 47 http://67-72chevytrucks.com/vboard/s...d.php?t=386848 |
#14 |
Re: pictures
Sweet build, great job on all the work!
#15 |
Yellow truck club
Re: pictures
Good job on the posting of pics because we like them ....
................................................................ Brian ...... ![]() My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW ![]() ![]() ![]() ![]() PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
#16 |
Re: pictures
good progress...
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#17 |
Re: pictures
lookin good brother
#18 |
![]() Join Date: Nov 2008
Re: pictures
Nice work, i like your work.
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair 99 S10 http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
#19 | |
#20 |
Re: pictures
Good lookin' build. I hope to see more of this one. Nice welding too.
56 Chevy PU http://67-72chevytrucks.com/vboard/s...d.php?t=531955 Question: Know how to sell your truck for $50,000? Answer: Spend $100,000 building it. |
#21 |
Re: pictures
looking good, keepup the good work!
#22 |
Re: pictures
The originator of this thread has not posted since Oct/2011
#23 |
Re: pictures
Wow nice work and you are sure making me look like a slacker. That truck looks like it is really coming along.
#24 |
Re: pictures
what brand of converter is it?
#25 |
Re: pictures
Haven't been on here in awhile. Finally getting some color on my 56 chevy pickup
