gas tank drain
does anyone know if there is a drain plug on a cab mounted gas tank, or any way to drain it with out removing the tank?
69 lwb fleetside, 307 2wd |
Cantankerous Geezer
If there isn't a tap to drain off the fuel line out the bottom of the tank, drain it by disconnecting the fuel line. You don't want to remove the tank with fuel in it unless you can avoid it, first it will be too heavy, second you will probably spill fuel in the cab.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
There is no plug/drain. I remove the fuel line under to cab and let it siphon off as much as possible into a gas can. Then I take my air compressor with the blower and cup my hand over the filler neck and put some pressure in the tank and hold my hand over it. Sounds like someone taking a wizz under the cab. Just gets a little boring standing around with you hand over the cap. I wonder if a cap could be 'massaged' to take a tire valve stem. Talk about getting the unleaded out.
http://home.comcast.net/~r.landrum/w...tos.html-.html '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. |
i took a radiator pressure tester and fabed it to go over the fuel filler and just pumped the last out
The very atmosphere of firearms everywhere restrains evil interference. When firearms go, all goes, we need them every hour. - George Washington No free man shall be debarred the use of arms - Thomas Jefferson Later Darren ![]() http://www.myspace.com/dmurphy68 |
its all about the +6 inches
I've always pulled mine with what ever was left in the tank.
Transcendental Trucker
If your truck is like mine, you could just start it up and it'll drain the tank pretty quick by itself. HEHE.
![]() When I pulled mine, I siphoned what I could out and then pulled it with about 1/4 tank in it. No problems at all.
Patrick Sullivan | sullivan@oregoncoast.com Rockaway Beach, Oregon 1972 Chevy Cheyenne C-20 1998 Dodge Dakota 4x4 So, fill to me the parting glass And drink a health whate'er befalls... Then gently rise and softly call Goodnight and joy be to you all! |
