Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-02-2010, 10:18 PM   #1
Hart_Rod
Hart_Rod's Avatar
What is the best header for ....
a 383 with a vortech supercharger? I have long tubes now, but they look pretty crappy and I'm wanting to upgrade. I was thinking about these:
http://www.dougthorleyheaders.com/pr.../productID/795
Thoughts?
Hart_Rod is offline   Reply With Quote
Old 04-02-2010, 10:24 PM   #2
nomrlz
nomrlz's Avatar
Re: What is the best header for ....
those seem small. i would want 1 3/4 primaries and 3" collectors.
nomrlz is offline   Reply With Quote
Old 04-03-2010, 04:09 AM   #3
darthwall
thorleys are nice headers no doubt about it try and find a set of the old doug thorleys 1.75 primaries and 3.5 collectors but I have only seen one pain good luck with that setup just run some super comps and wrap them
darthwall is offline   Reply With Quote
Old 04-03-2010, 07:03 AM   #4
ripdog28
ripdog28's Avatar
I dont know for sure but i believe those are Tri Y. I read somewhere that Tri Y headers are very particular on tuning and RPM power. More so then regular 4-1 longtubes. I would research it if i were you. Ill try to find the article.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 04-03-2010, 05:36 PM   #5
Alex1
Alex1's Avatar
Something from Hooker, 1 7/8 or so. This is a 600+hp set up right?
Alex1 is offline   Reply With Quote
Old 04-03-2010, 06:45 PM   #6
Hart_Rod
Hart_Rod's Avatar
The rest of the exhaust is 2.5". I plan on puttin in some electric cutouts so, I might do the 3" ....
Where do you find them?
Let me know.
You are correct on the HP. Do you have any part numbers? I may add some juice to it after I get everything else figured out...... I would also like them to not come down so far so I can have some better ground clearance, but I'm betting I'm not going to be able to have my cake and eat it too.....
Old 04-03-2010, 07:27 PM   #7
Alex1
Alex1's Avatar
Depends, some say you can use Chevelle headers which don't hang so low.
Old 04-03-2010, 08:19 PM   #8
darthwall
I have been running camaro headers and they hang just below the frame I think most of the pass cars headers will work and they wont hang nearly as low as the truck headers do and the old thorleys good luck finding them
Old 04-03-2010, 09:41 PM   #9
Hart_Rod
Hart_Rod's Avatar
Any part numbers or other fitment issues with these? Thanks,
R/
Old 04-03-2010, 10:18 PM   #10
big_al_71
big_al_71's Avatar
Thoughts?
those are the headers in my truck come september it will be two years, they are great my motor made tons of power with them, however I dont know how they will work for you with the truck being on air...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 04-04-2010, 12:42 PM   #11
darthwall
I dont have a part# on them its been 10 years since I put them on but there is no fitment issues the collectors come out straight into the trany crossmember but any muffler shop can make them work
Old 04-04-2010, 03:24 PM   #12
Hart_Rod
Hart_Rod's Avatar
Figuring this supercharger stuff out has been a journey.....
What year of Camaro?
Old 04-04-2010, 03:29 PM   #13
darthwall
68 camaro
