Old 04-02-2010, 10:19 PM   #1
BigRed76
BigRed76's Avatar
Horn Wiring?
While driving down the road today some idiot in a honda element cut me off after nearly side swiping me, and in my attempt to blow my horn at him i reminded myself how the horn doesn't work. I have looked in 3 different repair manuals for my 76, and none of them show a wiring diagram for the horn, or even mention where the horn relay is. The horn button in the steering wheel is all complete and both horns are present with wires running from them to the firewall. So my question is where is the horn relay? and do the wires from the horn button run straight to the relay?
Any info about this would be a huge help.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 04-02-2010, 11:59 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: Horn Wiring?
the horn relay is under the dash around the area of the fuse block
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-03-2010, 12:00 AM   #3
oldford
Re: Horn Wiring?
This isn't much help, but it's all I have... I have the factory wiring diagram for a '78 and it shows a horn relay with a dark green wire to the horn(s), a red one with 12v on it and a black one to the horn button. No note on location of the relay itself. If noone else posts anything, I'll look tommorow on my 78 (it's a six so I should be able to see it) when it is light out.
GL, Eric
oldford is offline   Reply With Quote
Old 04-03-2010, 07:38 AM   #4
RuralRoute C-30
RuralRoute C-30's Avatar
Re: Horn Wiring?
One of the non-working items on my 85 C-30 was the horn. My first priority to get passed in the required safety lane for this state was to get it working.
After messing with the oem with no luck, horn relay, steering wheel, etc., it turned out the horns themselves were rusted out. Yet even with a new horn relay and horn, the button on the wheel failed.
To fix this quickly: $20 for a horn kit at the local auto parts store. To get the safety sticker I initially wire-tied the horn button on the column. Since then, while cleaning up the wiring and the interior I come up with the idea to install this aftermarket horn button in the lower left corner of the floor. Basically it now is located and used, when needed, like the old headlight flashers that once were located in the floor of vehicles (for those who can remember that far back! )
Might be an alternative cheaper and easier for now than the other option.
Mark
1985 Chevy C-30 Hydraulic Dump Bed
2001 Saturn SC2 (go to work car)
2010 PT Cruiser (wife's car)
"Reality is just a hallucination brought on by lack of alcohol."
RuralRoute C-30 is offline   Reply With Quote
Old 04-03-2010, 09:44 AM   #5
oldford
Re: Horn Wiring?
Yep, hangs out of the harness right in front of the fuse box. You should be able (with an ohmeter) to see a ground coming on the black wire from the button. Should be 12v all the time on the red, and if you jump 12v to the dark green (mine looks violet) the horn should sound.
GL, Eric
Old 04-03-2010, 06:05 PM   #6
BigRed76
BigRed76's Avatar
Re: Horn Wiring?
So i found the relay, it was very obvious but somehow i missed it when i first looked. All wiring for the horns is good, but the relay doesn't work. So then i used a jumper wire to bypass the relay, and still nothing. After doing this i pulled the horns out and connected them straight to the battery and neither of them work. So now i need to find the best deal on a set of OEM horns.
Zach
Old 04-03-2010, 07:12 PM   #7
Panelman55
Panelman55's Avatar
Re: Horn Wiring?
When my horn doesn't work I use my 357mag. It gets the point across real well.
In God We trust!!!
Panelman55 is offline   Reply With Quote
