04-02-2010, 10:56 PM | #1 |
Life, Be In It.....
I would like some brake help...
The push rod from my booster is not long enough to reach what it pushes on in the master cylinder. The opening in the master cylinder so in about 1 1/2 inches. The threaded portion of the push rod is only about 1 inch long. How do I fix or change this? There are some pictures of both
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
04-03-2010, 06:00 AM | #2 |
Re: I would like some brake help...
The master cylinder does not match the booster. It looks like the booster rod is made for the stock master cylinder.
Can the rod on the booster be replaced? Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
04-05-2010, 11:48 AM | #3 |
That pushrod you are running is NEVER to be extended out like that. That pin is for a shallow bore master and you have a deep bore master. We have a long pin for deep bore applications. Call me and i will send you one. Thanks Bro!
04-05-2010, 12:13 PM | #4 |
nice looking firewall
04-05-2010, 12:50 PM | #5 | |
Life, Be In It.....
The correct part is on its way from CPP.
04-05-2010, 01:01 PM | #6 |
