brake lines
I am removing the body on a71 k5 blazer I have everything unhooked except the brake lines. how do you go about get the lines off can you just unbolt the line from the brake booster and master or is their more that needs to be done to the brake before remove the body .
Re: brake lines
just disconnect them from the proportioning valve. that's the only place where the brake lines are connected to the body. did you disconnect the parking brake cable and speedo cable?
Re: brake lines
disconnect them from the proportioning valve and disconnected the speedo cable i am having trouble with the parking brake cable
