Old 04-03-2010, 10:26 AM   #1
burke117
how low can i go?
what is the lowest i can use drop coils and still get an alignment and not need a c notch? Would a 2"/4" or a 3"/5" be better? I plan on upgrading to spindles in the future but money is tight right now. thanks
burke117 is offline   Reply With Quote
Old 04-03-2010, 10:46 AM   #2
OhOneWS6
OhOneWS6's Avatar
Re: how low can i go?
2/4 if you want to keep the stock spindles and shock location in the rear. If you go any lower you will be a lot better off with drop spindles. The 2" springs will not be wasted. Later you can use them with drop spindles for a 4.5" front drop.
OhOneWS6 is offline   Reply With Quote
