Old 04-03-2010, 04:40 PM   #1
project67-stepside
project67-stepside's Avatar
cross drilled rotors?
has any body done there own cross drilled rotors< is it easy, and what size bit< both sides? new guy here hook me up plz
project67-stepside is offline   Reply With Quote
Old 04-03-2010, 05:08 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: cross drilled rotors?
Cross-drill your own rotors? I'd be very leery of doing it at home. To me, there are balance issues, which mean that that the spacing on the holes you drill should be consistent and deliberate. If you don't keep the rotor in -balance, you'll know it soon enough. I haven't measure any of the holes I have seen, but they look like .025 inch to my wandering eye.
Member Nr. 2770
Old 04-03-2010, 08:10 PM   #3
midevil1
ShortBus KingPin
midevil1's Avatar
I did my own on at least 10 of my vehicles. There is no balance issue , but you do need to keep your pattern true the whole way around the rotor.
I did these for the front of my 67. They are off of a 72 Impala 454SS. Implala's used the same bearing size as the 1/2 ton trucks. Very cheap way to upgrade your front brakes. Rotors, calipers, and pads were under $100 bill at Advanced Auto Parts.
67 shortstep prosteet. 505 BBC, FULL BILLET TH350, Owner built EVERYTHING.... (My RIDE)
2008 GMC Yukon DENALI, 425 AWHP, 5700LBS, 12.40's at 109mph. (Her RIDE)
2006 Kawasaki Brute Force, 916cc, 80 shot, 6.20's at 111 mph. (Her RIDE)
midevil1 is offline   Reply With Quote
Old 04-03-2010, 10:07 PM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
WOW never seen this one...
How true does it need to be? I love DIY cheap/free mods! Is it that noticible in braking?
John
1999 Toyota Tacoma 4x4
Old 04-03-2010, 11:43 PM   #5
midevil1
ShortBus KingPin
midevil1's Avatar
Divide out the amount of holes you need to cover the entire rotor in a even pattern at the figured distance apart and mark your spots and drill all the way thru from one side to the other. 1/4" holes and all must be chamfered. I then clearcoat the rotors for a rustfree life. Becareful to make sure you dodge the cooling fins. I have seen aftermarket rotors drilled thru the fins and they ended up cracking. Mass production at its best.
Old 04-04-2010, 01:06 AM   #6
project67-stepside
Thanks guys i really appreciate the advice, ive built plenty of old vws, and now dodges, but never did it thanks again.
Old 04-04-2010, 10:11 AM   #7
brans72
I have never seen this done but my friend did his own slotted rotors with any problems on both his cars and they work as good as the aftermarket slotted rotors he had on car. Cool idea though and if it works it works.
brans72 is offline   Reply With Quote
Old 04-04-2010, 12:16 PM   #8
MacSic66
Active Member
MacSic66's Avatar
hey.. just wondering whats the lug pattern for the rotors? will they replace the 1 1/4" 73 and newer rotors? also.. what tube a-arms are u running?? thanks-Mark
No vehicle is "too nice" or "too straight" to cut up.
MacSic66 is offline   Reply With Quote
Old 04-04-2010, 10:32 PM   #9
midevil1
ShortBus KingPin
midevil1's Avatar
5X4 3/4 bolt pattern. I would check and see if your bearing fit in the rotor race before purchasing. Might have upgraded the bearing size on the 73 and up trucks. My A-arms are from POL. They had a sale for a complete frontend kit with drop shocks and your choice of springs for like 849.95. Had to buy it for that price.
