Old 04-03-2010, 06:19 PM   #1
CG
BlahBlahBlah
Motor mount pics for Livrat
Hey Mark thanks for stopping out today. I turned the place upside down and found those motor mounts we were talking about.
I bought em here off the board quite awhile back. I do remember asking (don't remember who now) if these were correct for the swap and was told yes. Let me know what you think.
Old 04-03-2010, 07:19 PM   #2
eric67m
eric67m's Avatar
Re: Motor mount pics for Livrat
Your workbench is too clean. You need some tools and some random clutter. I could help you out with the clutter, my garage has more than enough.
67 K10, lwb, fleetside, 327, 4spd, 205, cab and 3/4 frame swap, 14 bolt, big window, and a "rustoleum roll job"
eric67m is offline   Reply With Quote
Old 04-03-2010, 07:19 PM   #3
Livrat
Member #1049
Livrat's Avatar
Mark, Took a look through all my pics and even Al's post on the Caddy install, Could not find out if those are the exact ones needed or not.. I guess we will find out when we test fit the 500... I can bring 2 other styles just in case..
Livrat is offline   Reply With Quote
Old 04-03-2010, 07:50 PM   #4
CG
BlahBlahBlah
Well the work bench is freshly built and not quite finished. I did take some junk off it so Mark could get a good look at the mounts. Btw, after checking out my hitch more I think Im going to go with the extra mount system that makes me move my spare. Mark pointed out that it actually took off a small corner of the frame. And he noticed it had been cracked for awhile before it went all the way. So you're off the hook on the welding ... for now
Well that will suck if these dont work. Ive thrown away way too much money putting parts together for the panel.
Old 04-03-2010, 08:17 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
73-87 frame mounts in that picture.
Old 04-03-2010, 08:25 PM   #6
CG
BlahBlahBlah
Thanks for the clarification. I wasnt sure on the year of these and I should have called them frame mounts not motor mounts.
Old 04-03-2010, 08:28 PM   #7
Tx Firefighter
Mounts, stands, all the same to me. I just wanted to point out that they were 73-87. A lot of folks get them confused with 72 only big block mounts.
Old 04-03-2010, 08:33 PM   #8
Livrat
Member #1049
Livrat's Avatar
Kevin.. thanks for the clarification.. I totally forget to mention/post that..
I have found 4 different versions of the 73-87 Tower/mounts..
I do know that the ones pictured are not the ones to use in a Big block chev install in a 67-72 truck.. (they will make the engine sit up too high in the front) I do not know remember if those were the exact style we used in a Burb/Caddy install I did a couple years ago.
Old 04-03-2010, 08:41 PM   #9
CG
BlahBlahBlah
Guess I wont need to drag out my 72 big block towers then. Im checking out threads with Caddy swaps now.
