Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 04-03-2010, 09:25 PM   #1
jmedero
jmedero's Avatar
4.3 swap to a newer 4.3 swap
Ok I have a wrecked 2000 with a 4.3. I just picked up a 94 SS S10 with a "bad motor". Can I pull the one out of the 2000 and swap it into the 94? Can I swap the heads and intake? That supposed to be the problem with the 94. Any help would help.
Juan
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 04-04-2010, 07:39 AM   #2
68C15
blood type; Retumbo
68C15's Avatar
Re: 4.3 swap to a newer 4.3 swap
externally they are identical aside from the water pump bypass hole. this is a can of worms I doubt you want to open.
is the 94 actually bad? I ask this because many time I have seen the alt locked up and the engine wont turn over without removing the belt.
68C15 is offline   Reply With Quote
