Old 02-06-2003, 11:11 PM   #1
chevy garage
chevy garage's Avatar
Question Hey Dion, Question for you
What is your steering wheel adapter off of? 68 Camaro/Chevelle? I know there are different sizes but yours fits good.
chevy garage is offline   Reply With Quote
Old 02-07-2003, 01:21 AM   #2
dion
72 Cheyenne
dion's Avatar
I believe it's from a late 60's Chevelle, it had the adapter on it when I bought it and it went right on in 10 mins. I have a little problem with the ground though, you have to push hard to get it to honk and I get a little shock.
Burnout
Idle
1972Cheyenne
1966/67Stouts
dion is offline   Reply With Quote
Old 02-07-2003, 06:04 AM   #3
Lippyp
English Chevy Owner
Lippyp's Avatar
Nice looking interior, my wife would want me to fit a steering wheel that gives you an electric shock when you use it, she thinks I use mine far too often!
Phil
'67 C10 long fleet.
350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon
2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission
Lippyp is offline   Reply With Quote
Old 02-07-2003, 09:39 AM   #4
chevy garage
Thanks for the help. You may need to wear ya some weldin' gloves when you drive er. That might keep ya from gettin' juiced up!
Thanks Again
CG
Old 02-07-2003, 02:00 PM   #5
jhow66
jhow66's Avatar
shock
Hey Dion, if you are getting a shock that means the circuit is using you to go to ground. Check to see if the truck body is grounded to the motor and frame.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 02-07-2003, 03:55 PM   #6
Mike C
Mike C's Avatar
I bought my wheel from Muscle Factory. It has a 69 adapter. The 69 passenger cars have a slightly larger diameter column than the earlier cars. This to accomodate the locking steering column. SO if you buy one for your truck, get a 67-68 Camaro Comfort Grip package. Muscle Factory was cheapes I had found at $160, but they have since gone up to $200. Complete, however. Adapter, bolts, horn kit, contact kit, button, etc.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-07-2003, 10:17 PM   #7
dion
72 Cheyenne
dion's Avatar
Thanks, I'll check for the grounds.
Burnout
Idle
1972Cheyenne
1966/67Stouts
