Old 04-04-2010, 01:18 AM   #1
West Texas Z
El Mero Mero Frijolero!!
West Texas Z's Avatar
REAR hazard, brake, and turn signals dont work.
Like the title says, the REAR brake, hazard, and turn signals dont work. The front and sides work perfect but I'm having issues with the rear end. The clear reverse works and the ones that are supposed to be on at night work at the back but the others dont. I've checked the fuses, replaced the bulbs and checked the wires. What could it be? My dad thinks that it may be the pin switch but 12volts are running to the switch with a test light.
I'm so confused and I need rear lights! help please.
West Texas Z is offline   Reply With Quote
Old 04-04-2010, 01:19 AM   #2
West Texas Z
Re: REAR hazard, brake, and turn signals dont work.
Here is a pic of the switches. It has two, one for the brake pedal and one for cruise control. (It doesnt have cruise control BTW.)
Old 04-04-2010, 11:41 AM   #3
James McClure
One shot, one kill.
Tex: This may be the classic infamous trailer wireing problem. If you have a hitch connection look at it closely where wires are spliced in, then move up the truck harnace to the factory plug in for the rear lights, pull it appart and look for corrosion. Keep a test light with you and check at each step. If all is good and still no power back there, try plugging in a signal light switch and operating it. All the lights you mention go thru this switch, even the brake lights. Let us know, Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 04-04-2010, 08:21 PM   #4
drtfun4x
drtfun4x's Avatar
I had the same problem lights worked off and on at times found that my turn signal switch was all messed up changed it and no more problems
just an idea
Terry
drtfun4x is offline   Reply With Quote
Old 04-04-2010, 08:58 PM   #5
54Caddy
GM Addicted
54Caddy's Avatar
i have had the same problem, Mine was because the turn signal harness connector check that out. push them together good and see if they work might have to clean out the dirt in the connector maybe. good luck man that **** gets annoying to figure out.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 04-04-2010, 09:45 PM   #6
West Texas Z
Thanks for the info on the switch!! Ive posted this question on different forums and I've gotten the same result. I'm going to check that and see if anything changes. Thanks again.
