Old 04-04-2010, 09:06 AM   #1
1LowToy
Spare tire ?
Anyone have any better set-ups for mounting the spare tire? I see the factory one as being a potential PIA once my truck is lowered. I could just see a flat tire in the back and no way to get the spare out. I was thinking maybe one out of a toyota or as old as I am maybe just a AAA account?
1LowToy is offline   Reply With Quote
Old 04-04-2010, 09:10 AM   #2
sailed2japan
Jonny
sailed2japan's Avatar
Re: Spare tire ?
If you're getting long in the tooth, maybe an AAA account would be best. other than that you could use or make a mount like in the 60-66 trucks that hold the spare vertical in front of the wheel tub inside the bed.
Edit:
Here's a wite up from Tx Firefighter, took a minute to find it:
http://kneeknockertruck.blogspot.com/
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 04-04-2010, 08:14 PM   #3
1LowToy
Re: Spare tire ?
Bump
Does everyone with a lowered truck carry the spare tire in the stock rack?
Old 04-05-2010, 07:20 AM   #4
Keith Seymore
Keith Seymore's Avatar
Re: Spare tire ?
Mine's up in the bed.
If you don't feel like making a rack like Firefighter did (great job, by the way) you could probably find one of these in the junkyard or at a dealer.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-05-2010, 08:39 AM   #5
chrismoore701
chrismoore701's Avatar
Re: Spare tire ?
I saw someone used a crank style, like you see on modern trucks. I am thinking about that, what do you guys think. not sure if I want the tire in the bed. I have a 3-4 lower kit on my '79 stepside
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 04-05-2010, 09:34 AM   #6
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Spare tire ?
The 3" exhaust pipes done away with the stock spare placement on my 97, I mounted it flat in the front right corner of the bed with a 1/2" threaded rod welded to a square 3/16" thick plate bolted to the bed floor. I'll be doing the same with project 74, Since both these trucks are show only not dd's I have no problem with the spare placement since all either will ever haul is chairs/canopy and a cooler and the tonneau covers it all.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 04-05-2010, 04:37 PM   #7
Scootin 81 C20
3/4 Ton Rodder
Scootin 81 C20's Avatar
Re: Spare tire ?
Here's mine. The bracket can be made out of some C channel and threaded rod. If you would like more pics of it, let me know.
1981 Chevy Scottsdale C20 "Orange Crush": SOLD
1989 Chevy Silverado K2500: All Stock (For Now), 350 TBI/700R4. DD/Light Duty Toy.
Scootin 81 C20 is offline   Reply With Quote
Old 04-05-2010, 08:48 PM   #8
Keith Seymore
Re: Spare tire ?
I used a crank style on my open car trailer; it's nice as far as raising and lowering the tire but I don't think you'll pick up any packaging space. You still have to fit the tire up under there regardless of how you hang it.
MHO -
K
1979-1986
1986 - 2019
Old 04-05-2010, 10:13 PM   #9
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
Re: Spare tire ?
anyone used a do-nut or space saver from a full size car? something smaller, that would fit under the bed?
tommie is offline   Reply With Quote
