Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 04-04-2010, 05:44 PM   #1
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
interior leak
Ok i found water on the floor on the passenger side the carpet is wet but not soaked and its right in the corner under the dash by the trans hump. I know its 99,99% the heater core but is there anyplace else these suckers leak? pr something else to inspect before i spring for the core?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-06-2010, 02:21 PM   #2
Myself
Re: interior leak
A/C drain hole may be blocked. Causing condensate from the evaporator to back-up and drip inside. Does it smell like anti-freeze?
Myself is offline   Reply With Quote
Old 04-08-2010, 07:04 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
Re: interior leak
these are not known for having exterior leaks but I would still check. remove the glovebox and watch while someone hoses it down.
the evaporator drain is a bit** to get at, you will need to go at it from underneath (on a hoist)
IIRC rain water does run through there, you guys had a bit of rain lately right?
68C15 is offline   Reply With Quote
Old 04-08-2010, 11:37 AM   #4
michael bustamante
michael bustamante's Avatar
Re: interior leak
boy I hope its not the heater core! I just replaced mine in my grandfather 94 s-10 and I poray I never have to do that again!, I was thinking condensor drain line is plugged also. have you been running the a/c?
1967custom
michael bustamante is offline   Reply With Quote
