04-04-2010, 06:03 PM | #1 |
72 GMC grille signal light lens
Those rivets or what ever they are that hold the lens to the housing how do the come out without damaging the housing? I'm using clear lens so I'm not saving the lens. I have new lens,screws, gasket and the round things that look to be some kind rivet. What holds the round things in?
04-04-2010, 07:17 PM | #2 |
2WD Jimmy
Re: 72 GMC grille signal light lens
As I recall, I just used a drill to drill off the heads of the rivets and then the lense came right off.
04-04-2010, 09:03 PM | #3 |
Ok Thanks
04-04-2010, 09:48 PM | #4 |
18 Till I Die
I just drilled them out and rivited new ones on when you used to be able to buy new ones form GM
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
04-04-2010, 11:23 PM | #5 |
Sisyphus was my mentor!
I ran a 5mm tap right through the lens into the housing & installed stainless phillips screws so that it could be opened up again easily if I ever had to.
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
