Active Member
![]() Join Date: Nov 2007
5on5 to 5on4 3/4
i have a 1973-87 crossmember with djm 3" drop spindles, 1 1/4" thick rotors.. im looking to change to 5on4 3/4 lug pattern in the front. ive hunted around and found some info on it.. but doesnt seem i can find a straight swap rotor wise? or is machining and redrilling the only way with the rotors and spindles i have? anybody conquored this delema?? any help is greatly appreciated!
-Mark
#2 | |
ShortBus KingPin
Re: 5on5 to 5on4 3/4
67 shortstep prosteet. 505 BBC, FULL BILLET TH350, Owner built EVERYTHING.... (My RIDE) 2008 GMC Yukon DENALI, 425 AWHP, 5700LBS, 12.40's at 109mph. (Her RIDE) 2006 Kawasaki Brute Force, 916cc, 80 shot, 6.20's at 111 mph. (Her RIDE) |
My Carbon Footprint
Seems like the obvious question is why do you want to go to 5 4/3 bolt pattern?
Active Member
because.. im pretty sure i have more options for wheels with the car pattern... and the rear is allready 5on4 3/4..
#5 | |
Active Member
sweet! im going to give it a try this week.. see what im up against.. whats the width of the impala rotor?
ShortBus KingPin
1.25 is the thickness and you will have many more wheels to choose from with the car pattern. I'm running the impala calipers too.
#7 | |
Active Member
ohh, is the rotor diamater the same as the trucks? thanks, muuuccchh appreciated!
Performance online sells them
70 SWB STEPSIDE 70 BLAZER 09 challenger |
ShortBus KingPin
I believe they are alittle over 12" in diameter.
