Old 04-04-2010, 10:26 PM   #1
tim21391
tim21391's Avatar
bed bolt shopping?
wheres a good place to look at for bed bolts to assemble my longbed.. i am swapping floors out to a different steel floor since mine was all holey... so i need new bols going from the sides to the floor the front panel and all.. also i want new bed to frame bolts.. i looked at a place and started tallying it up to over 100-200 bucks.. is that right?
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 04-05-2010, 12:08 AM   #2
MT71c-10
Too many toys,not enough money
MT71c-10's Avatar
Re: bed bolt shopping?
Might be cheaper to try your local hardware store. I've had to correct some mistakes from one of the big resto co's, and found buying in bulk much cheaper, just make sure all the bolts are the same.
Looking for all Montana members. PM me or send friend request.http://www.67-72chevytrucks.com/vboa...36#post3813336
MT71c-10 is offline   Reply With Quote
Old 04-05-2010, 04:37 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Tractor Supply sells carriage bolts for about 3 bucks a pound. You should be able to get all of the bolts, nuts, and washers to do the entire bed for well under 20 dollars.
Old 04-06-2010, 02:28 AM   #4
Aarons72s
I second Tx Firefighter on that. Also if you want chrome or stainless you can try ACE as they do stock some.
Aarons72s is offline   Reply With Quote
Old 04-06-2010, 07:18 AM   #5
mrein3
mrein3's Avatar
Anybody know off-hand what lengths, sizes, and amounts?
I'm in the same position. I have one disassembled and want to get to that this spring.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 04-06-2010, 09:25 AM   #6
m6z
m6z's Avatar
I'd also like this info. If any one is in the process of putting a bed togeather right now please post the info.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 04-06-2010, 09:35 AM   #7
cdowns
cdowns's Avatar
count and measure is that soooo difficult?????
Old 04-06-2010, 09:42 AM   #8
m6z
m6z's Avatar
Not difficult, but If one person has allready done the work. Why not share the info with the rest of us and save us some time? Plus the bed I have is in peices so I don't have any of the original hardware to compare.
Doug
Old 04-06-2010, 09:47 AM   #9
robzilla
robzilla's Avatar
would these work for wood bed replacement?
robzilla is offline   Reply With Quote
Old 04-06-2010, 10:14 AM   #10
msgross
msgross's Avatar
You could make it work, The only difference it the offest washers and bolts for the main bed mounting, I had a set of those for sale on the parts board...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-06-2010, 12:53 PM   #11
tim21391
tim21391's Avatar
ya i dont have the bolts to measure i either cut and drilled them out or i just kept tightening the bolts until they broke off then i just left them in the grass..
Old 04-06-2010, 12:57 PM   #12
Tx Firefighter
Sucks to mow your lawn I'd bet.
Old 04-06-2010, 01:00 PM   #13
msgross
msgross's Avatar
You should be able to get a rough idea by using some old bolts that you have lying around... Most of the assembly bolts are 3/8 i think and the mount bolts are 7/16 or 1/2 at the most. I'd run to Tractor Supply, pick up a few grade 2 bolts of different lengths and test them out... then buy what you need. Only cost 50 cents to pick up a handful of choices.
The Garage:
Old 04-06-2010, 02:18 PM   #14
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
There was a thread with pictures and lengths for each position around here somewhere..
My bad, the thread I mentioned was for Blazer body mount bolts..
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 04-06-2010, 05:18 PM   #15
Fitz
MMS & Accessories has a complete bed bolt kit in polished stainless. Why measure and count when someone else has already done it for you???? And yeah...it ain't cheap. Entire truck kit is 379.00
Fitz is offline   Reply With Quote
Old 04-06-2010, 07:10 PM   #16
Tx Firefighter
Question and answer both right there. I can do a whole lot of measuring to save some money. On my junk, I actually ordered a basic zinc plated kit from Mar-K for 50 bucks. I figure I could have assembled my own hardware for about half that, so some convenience for 25 bucks was worth it to me.
Old 04-06-2010, 07:45 PM   #17
tim21391
tim21391's Avatar
ha ya tx i dont mow my lawn my 11 yr old brother does so he will have a surprise maybe haha.. its rained so they might of sunk in the ground
Old 09-20-2010, 02:45 PM   #18
STINEY
STINEY's Avatar
I used 4" 3/8 zinc coated bolts nuts & nuts from TSC this weekend. 8 of them worked fine for my '67 1/2 ton with steel floor.
$5
Bucyrus, Ohio
https://i.imgur.com/TeUPWqt.jpg
STINEY is offline   Reply With Quote
