04-04-2010, 10:49 PM | #1 |
Primer to avoid top coat problems?
To all of you seasoned restorers, what are the best primers (or a good way to pick a primer) to ensure compatibility with the possible top coat/clear coats? e.g. is there any compatibility issues with aftermarket parts that come primed, or with using a Dupont primer if you later wanted to use a PPG top coat, vice versa, etc.?
Thanks. Mark (We'll probably do the priming ourselves...haven't decided on the top coat yet and my do that with a pro or experienced amateur shop). |
04-04-2010, 10:50 PM | #2 |
Re: Primer to avoid top coat problems?
ive had good luck with 2k100 urathane.. ha i dont think i spelled that right
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
04-04-2010, 11:11 PM | #3 |
Saving 1 truck at a time!
Purchase all of your products from the manufacturer!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
04-04-2010, 11:14 PM | #4 |
Two important points in painting old vehicles:
- Do some type of rust stabilization with the first coat, lie a self-etching primer - Cover the primer with a sealer coat that will keep the solvents in the color coats from loosening the primer coat. This sealer is usually sprayed on right before the first color coat. Note the sealer coat is usually given a tack-rag pass once set.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
04-05-2010, 12:07 AM | #5 |
Welcome! You should be OK with what you've got planned.
The E-coat primer on aftermarket parts shoud be sanded and reprimed, IMO. It's not a good idea to use, say, brand X activator in brand Y primer.
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
