Rear Disc 3/4, 1ton
What's out there for kits/DIY for rear disc conversions on the corporate 3/4 and 1 ton axles? I've searched quite a bit and can only come up with half ton stuff...
Re: Rear Disc 3/4, 1ton
ORD or ORU has the kit, i had it on min old truck but i cant rember which one made it.
#3 | |
Conversion Truck Addicted
Thomas Quote:
BAD BOW-Silverado XST
Ruff Stuff Specialties has pre-bent brackets and they are the only ones I will use, you can get them shipped to your door for $60. Use 14 bolt on your search, they also sell on ebay.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
One shot, one kill.
From the video it would appear that you could also do this same thing on the non floating 3/4 ton rear axel with all GM parts except the bracket. I noticed the end of the axel tube was 3/4 to 1" away from the bracket which would allow the rotor to sit farther in on the nonfloating axel and still leave enough room to work in a bracket and the caliper. Hub centers should be the same diameter, so I don't see why a rotor wouldn't just slide on like the drum would. I'm doing tire work on mine and I have some spare rotors so I'm going to look into this. Only problem I see right away is the emergency brake, but, Mico lock makes a fluid driven pressure holder that works like line lock for drag cars, but it's designed for tow trucks. I'll have to look into that also unless someone else beats me to it. I'm not real good with computers and such. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shot ![]() |
#7 | |
I actually was able to turn this up on eBay too....looks like a good way to go really.
http://cgi.ebay.com/ebaymotors/14-Bo...s#ht_633wt_940 Quote:
