Old 04-05-2010, 01:18 AM   #1
kanuck
1988 blazer
I just picked up an 1988 blazer 4wd. The truck has been parked for a year and only has 85,000 miles on a 350/ 700R4 drivetrain. It is part of an estate sale so I am not sure if I'm getting papers for a while or ever, but the truck is mine already. Don't know if I should get it running and do work to it or part it out.
Can I transfer the drivetrain to a two wheel drive frame I have that is sand blasted, has papers and is ready to reassemble?
Do the seats and the power window doors fit on a regular cab?
Thanks for any info....
'70 Malibu with 383 stroker/T350
'56 SWB Mercury pickup..under construction
'67 Firebird Convertible...all done stock
'70 LWB 350 on propane...beater
'69 LWB 350/T400 body restored
kanuck is offline   Reply With Quote
Old 04-05-2010, 10:54 AM   #2
andyh1956
Re: 1988 blazer
hey kanuk- it is doable & ive done it several times. you must remove all the spring hangers as they are longer on a 4wd than a 2wd. the seats will work but the seat bases wont, they are way too high. you may be able to cut them down, the bucket seat bases for a pickup are quite rare. good luck!
andy
andyh1956 is offline   Reply With Quote
