Old 04-05-2010, 01:32 AM   #1
63shortbox
63shortbox's Avatar
60-66 body's on newer frames
lets see some pictures of your 60-66 body on a newer frame or a custom
63shortbox is offline   Reply With Quote
Old 04-05-2010, 01:36 AM   #2
63shortbox
63shortbox's Avatar
Re: 60-66 body's on newer frames
63 on a 77 frame with a 3 inch lift, 33 inch mud terrains
350 target master bored .40 over with flat tops and cam
soon to have 3/4 ton axles with 4.10s and maybe 35s
Old 04-05-2010, 01:47 AM   #3
Captainfab
60-66 Nut
IMO it's ok on a 4x but on a 2wd it doesn't look too good with the body lift. I did a 2wd years ago, but I don't have any good pics. I'm trying to get a hold of the current owner to get some pics since this question comes up quite frequently.
Old 04-05-2010, 08:03 AM   #4
jason65
Registerd User
jason65's Avatar
Here is what I got so far. Haven't had time to work on it lately. 64 going on a 84 4x4 chassis. Glad to see your tire lift combo. My bed is just sitting there. Still needs body lift.
jason65 is offline   Reply With Quote
Old 04-05-2010, 11:21 PM   #5
oklahomaduner
oklahomaduner's Avatar
66 GMC on a 86 chevy frame
1966 GMC Extended cab 1 1/4 ton 4x4
My build thread
1958 Chevy 1 ton dually flatbed
My Dad's build thread
1966 GMC Custom Trim Big Back Window W/351e
My Time-Killing Project Truck
1966 (Not So) All Original Chevy Custom Trim Suburban
My Dad's Time-Killing Project Truck
oklahomaduner is offline   Reply With Quote
Old 04-06-2010, 12:38 AM   #6
Franks Fab Shop
Franks Fab Shop's Avatar
62 GMC ona '73 4x4 , 3/4 ton,
Franks Fab Shop is offline   Reply With Quote
Old 04-06-2010, 08:56 AM   #7
Northern lights
'64 on an early '80's frame.
Northern lights is offline   Reply With Quote
Old 04-06-2010, 02:42 PM   #8
63shortbox
63shortbox's Avatar
could any of you take a picture and post it of how you mounted the front of the cab, i have some ideas but i want it to look clean just looking for some ideas.
for the rear of my cab i just cut off the old mounts then flipped them to the outside and trimmed them up a but and re mounted them ahead a couple inches.
Old 04-06-2010, 03:04 PM   #9
skidder111
skidder111's Avatar
Hey 63shortbox - I'm just getting ready to do this for my son; 1964 LWB on a 1980. Was it fairly simple? What did you do about the gas tank(s)? Cheers.
skidder111 is offline   Reply With Quote
Old 04-06-2010, 08:33 PM   #10
63shortbox
63shortbox's Avatar
hey skidder111, it was pretty easy, ill take some pictures of the mounts when i get it all done, im going either to put a fuel cell in the box or a tank out of a blazer between the frame rails in the back
Old 04-06-2010, 10:56 PM   #11
nbrfd007
nbrfd007's Avatar
Thanks for the topic, I have a 65 GMC I what to put on a 79 4 X 4 1 ton frame, with a flat bed.
nbrfd007 is offline   Reply With Quote
Old 04-07-2010, 12:20 AM   #12
srr
Nice work guys! I believe my 64 flatbed's frame is a graft between a newer frame in the rear because it has leafs and I can see where some metal plates were added just behind the cab.
You guys who swapped older bodies on to newer frames, did you have any issues with the steering shaft or anything else?
srr is offline   Reply With Quote
Old 04-07-2010, 12:18 PM   #13
62gmc910
62gmc910's Avatar
I haven't done the measurements, but the '73 to 90? suburban frame has the kick up further back and MIGHT work better
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 04-29-2010, 07:11 PM   #14
65ChevyUtah
Any luck on getting the cab mounted ? I will be working on mine this weekend. 65 on 77 frame. I have the front cab mounts and one of the back done. I'll try and post some pictures later this weekend. I am trying to keep the body of the truck as close to the frame as possible because I want to use a roll pan on the back and if I have too much body lift it will show the frame. Any pictures or ideas of any swaps would be awesome..
65ChevyUtah is offline   Reply With Quote
Old 04-30-2010, 02:01 AM   #15
Captainfab
60-66 Nut
Here are a couple pics I found of the one I did many years ago.....they're not the best pics. To give you an idea on the ride height, those tires are 31-10.50/15's. As I've said many times, I don't recommend this swap for a 2wd truck, unless you like the lifted 2wd look. Unless your original frame is totaled, just swap the suspension and drivetrain from the newer truck to the older frame that fits the body correctly. Another thing to consider is how your state/local DMV views a swap like this. It would suck to go thru all that work only to be denied a license or title upon an inspection.
Old 04-30-2010, 12:52 PM   #16
Franks Fab Shop
agreed with that captain, the frames are a bit different. when i first did this i sat the buban down on the frame and there was about 3" of space between frame and chassis along the front half to front bumper.
so i changed it by cutting the frame in half just behind where the front seats are (aprox), and raised the frame up to match..
much better now! now there is no clearance between the front fender wells to frame area. the front frame horns now fit right under the core support where bumper fits.
now this is a 4x4, and i'm going to build full cage to frame for "body mounts". but doing this a 2wd is crazy time. its much easier to modify frame to accept what ever suspension you may want to use
Old 11-14-2012, 01:55 AM   #17
Auctioneerhere
I'd love to see more pictures of this on 4x4's as that's what i am working on.
Auctioneerhere is offline   Reply With Quote
Old 11-14-2012, 09:31 AM   #18
UK62LW
UK62LW's Avatar
My 62 on a 77
Barney, in the UK
1962 Chevy C20
1974 Ford Econoline
1987 Peugeot 205 GTi
1991 Peugeot 205 GTi
UK62LW is offline   Reply With Quote
Old 11-14-2012, 10:31 AM   #19
64tantruck
64tantruck's Avatar
My truck sits on a 1978 3/4 ton chasis. Done by the Previous Owner
Glenn
64tantruck is offline   Reply With Quote
