04-05-2010, 08:15 AM | #1 |
Java Mechanic
C-10 v. C-20 frame
Is there a difference in the shapes in the C-20 and C-10 frame in the rear axle area?
I bought bolt in c-notches a few months back (I really don't remember if I specified that I have a c-20 or not) and finaly got to working on that part of the restoration this weekend. The things really don't fit well. I expected them to flush up to the outside of the frame (once the notch area was removed, of course) and they really didn't. There are some gaps and the bottom plate hangs outside the frame by about 1/2 an inch at the front. They are close enough that wanging on the one I have installed with a BFH got it mostly matched up but not close enough to make bolting it make sense. I welded it on where it does hit the frame and I'll be doing some trimming and making gussets and reinforcements to finish. With the peice not fitting flush; I didn't want to just bolt it up, leaving gaps for rust to sneak into between the peices. Not a show-stopper in the end, just kind of wondering is "sort of" fits is normal here, if I bought c-10 parts when I should have bought c-20 parts or if I just got a set that wasn't quite right?
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... Last edited by panhandler62; 04-05-2010 at 08:16 AM. |
04-06-2010, 08:25 AM | #2 |
Java Mechanic
Re: C-10 v. C-20 frame
Some veiws, no comments -- Either I made no sense or I posted such an "out there" issue that no one knew what to say! lol
Given the amount of rusted material I had to remove I'm thinking it would be a good idea to box in this section of the frame.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
04-06-2010, 09:44 AM | #3 |
Happy to be here
Keith I am no 67-72 expert. but I can tell you this seems to be a common problem. I don't think it matters if it's C-10 or C-20, there was just a lot of variance in the rear frames. I'll take a guess and say it may have had something to do with the plant they were manufactured at, but that just a guess.
04-06-2010, 09:51 AM | #4 |
Java Mechanic
At least my welding is improving as I work on it... lol
04-06-2010, 12:53 PM | #5 |
The main difference would be leaf frame vs. coil frame. The C20 3/4 ton coil frames should be shaped the same as C10 1/2 ton coil frames so that c-notch should fit w/minor tweaking.
I wonder if these bolt-in notches fit a lot worse vs. when I did mine back in 2000? Seems several have had similar complaints recently.
04-06-2010, 01:30 PM | #6 |
Java Mechanic
I got them to work, with the help of a BFH and some gusseting, but I really had expected them to flush right up. If I had known that I would end up fabbing (my fancy word for the hack I'm doing! lol) them in I would have bouht the weld on plates to begin with. lol
Oh well.. it's just time, bulk plate and burned fingers. I'm just all tickled to have the rust gone!
