Old 04-05-2010, 02:01 PM   #1
hotrod_991
hotrod_991's Avatar
rear end help.
I have a Ten Bolt under my 77 2wd LWB. does anyone know if the the truck 10 bolts were 8.5 or 8.2in? I am wanting to order a limited slip but cause figure out wich it is and Im not home to tear it apart and measure. Im assuming it would be an 8.5 cause i thought the cars had the 8.2.
THe back side of my rear end case is stamped GM81 if that helps at all. Thanks guys.
"Buckle up I wanna try somethin!!"
"of course it will hold!, I welded it!"
1977 c10 under knife for full rebuild, 5.3l 4l60e drive rain swap, replacement frame and green repaint
hotrod_991 is offline   Reply With Quote
Old 04-05-2010, 03:13 PM   #2
nlped
nlped's Avatar
Re: rear end help.
If it's the original rearend, then it is an 8.5".
Ed
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 04-05-2010, 05:33 PM   #3
ont_guy_38
ont_guy_38's Avatar
Re: rear end help.
^^^^^^^ what he said
ont_guy_38 is offline   Reply With Quote
Old 04-06-2010, 12:12 AM   #4
hotrod_991
hotrod_991's Avatar
Re: rear end help.
ok now the splines/ do the trucks have the 28 or 30 splined? or did they also have the 27? i know its a guessing game till i get home and tear it apart just tryn to make an educated guess here Thanks
Old 04-06-2010, 10:01 AM   #5
nlped
nlped's Avatar
Re: rear end help.
Depends if it is original. If it is a 8.5" rearend out of a 1987 or prior it has 28 spline axles, 1988 and newer have 30 spline axles. I haven't actually heard of a 27 spline 10 bolt.
The more I think about it though, I believe your truck should have a 12 bolt rearend under it. I recently sold a '77 LWB and it had a 12 bolt under it, and the '76 Blazer I have also has a 12 bolt. I could certainly be wrong about the application, but it is a consideration.
Ed
Carter
Old 04-06-2010, 11:04 AM   #6
hotrod_991
hotrod_991's Avatar
Re: rear end help.
yea someone before my must have swapped it out for some reason. It is supose to have the 12 bolt. Im assuming it is a 28 spline application. Think I might have a line on a parts truck with a 12 bolt tho so hopefully that come through. But if not looks like I am building the ten bolt.
