Old 04-05-2010, 02:58 PM   #1
longhorn396
S.D.M.F.
longhorn396's Avatar
Exclamation How do u adjust a carb if it is running lean??
i still havent figured out my carb. It is a carter quadrajet and it is running very rich. the exhaust stinks and it tries to die when i stop like it is flooding out. I am also having problems like drewdude92. backfiring and missing at slow accel and crusing speeds. Need some advice guys.
1969 Chevy Longhorn 396/400 3/4 ton.
1991 Chevy Camaro RS 305/700r4
1978 Honda XL175 and XL350(the evil twin)
2006 Kawasaki ZX-14r drag bike-best e.t. 9.4@145 mph without nitrous
1971 BSA Thunderbolt 650cc
longhorn396 is offline   Reply With Quote
Old 04-05-2010, 03:07 PM   #2
DT1
DT1's Avatar
Re: How do u adjust a carb if it is running lean??
Check the float level. Backfire could also be a timing issue.
I had a 441 Victor. Cool Bike
DT1 is offline   Reply With Quote
Old 04-05-2010, 03:10 PM   #3
longhorn396
S.D.M.F.
Thanks DT1. and that means i have to take the carb apart right. i had my dad and gpa rebuild mine cause i can do everything but figure these carbs out lol.
Old 04-05-2010, 03:12 PM   #4
cdowns
cdowns's Avatar
you're asking about iit running lean then describe it running rich???
what r your sparkplugs saying about it??
Old 04-05-2010, 03:14 PM   #5
longhorn396
S.D.M.F.
I meant rich lol. im just in a hurry today. But idk i havent pulled them and looked. but no one is answering my question how do u adjust it to not run rich
Old 04-05-2010, 03:31 PM   #6
lks dcvn
lks dcvn's Avatar
Try this:
http://www.ehow.com/video_5225931_ad...rburetors.html
lks dcvn is offline   Reply With Quote
Old 04-05-2010, 03:56 PM   #7
long67
long67's Avatar
You need to adjust your floats to the correct setting and set your air/fuel mixtier scews on the front of the carb. This can also be from incorrect metering rods or springs.
Mark
67 c20 custom camper
55 Olds 2dr hardtop
96 mustang
11 dodge nitro
long67 is offline   Reply With Quote
Old 04-05-2010, 05:00 PM   #8
cdowns
cdowns's Avatar
i'd check the fuel pump pressure and flo rates first b4 opening a carb
Old 04-05-2010, 05:09 PM   #9
John Pasinski
John Pasinski's Avatar
Go back to PAGE #4. Look at the post titled: Quardra-Jet Help Please! Lottsa good advice there. Hope that helps.
A man's thoughts devise his ways; but it's GOD that directs his steps.
John Pasinski is offline   Reply With Quote
Old 04-05-2010, 05:13 PM   #10
piecesparts
Parts and more parts
piecesparts's Avatar
You are sure it is a Carter brand quadrajet? I have had some experience with these carbs and it could be that your bowl and carb body has some defects in it. The Carter Quads have no bushings inserted in the body, where the needles go through it and the metal has a tendency to errode away and then you have a rich operation. If you go find a Rochester Quad and use that body, then you have the bushings inserted and the carb tunes stay where you set them. My experience was that the engine would run, but the transition into the secondaries created a big BOG due to the overfeeding of fuel. This is a simple but can be a costly situation.
Frank
piecesparts is offline   Reply With Quote
Old 04-05-2010, 05:55 PM   #11
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
You can remove the top of the carb to access the float and rods with it still on the engine...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-06-2010, 09:20 AM   #12
longhorn396
S.D.M.F.
Yes it is a carter. it was a dealer replacement carb that the owner before my gpa and he had, had it replaced. I rebuilt it and idk what my gpa adjusted the float too.
iks dvcn- thank u for the video i will watch it when i am somewhere i can here it haha
piecesparts- yea when i slow down i begins to bog but it doesnt really do it till my motor is at operating temp. Im planning on rebuilding my motor this summer and im just gonna put a edelbrock intake and carb on it. so there isnt a reason to buy a rochester. Thank u for the help though i didnt have a clue about that stuff.
GASoline71- Ok thanks
John P.- That page was a lot of help thanks.
