04-05-2010, 08:48 PM | #1 |
clutch fork
how is the clutch linkage attached to the fork, or does it just push againest it? Any pictures? Mine has been modified , I think. Mine floats around on the outside hole of the clutch fork.
1961 Apache short step. |
04-05-2010, 09:24 PM | #2 |
Intentionally Left Blank
Re: clutch fork
There is a wedge shaped piece with a hole in it. The rod passes through the wedge and into the fork. The long spring goes from the fork to the frame, keeping the wedge in place and holding the rod in at the same time. Sorry for the bad pic, but my truck is really low and this is from the top, with the camera sideways. Hope this helps, Jeff.
1965 C-10 Short Fleet 468/TKO 5-Speed 2004 2500HD Crew 496/Ally Blacked Out (SOLD!!) 1997 Formula WS6 2004 Jeep Wrangler (Sold) 2013 Jeep Wrangler (Sold) 2017 Jeep Wrangler (Blacked Out on 35's) 2011 GMC D-Max Dually Denali 3500HD (Sold) 2015 GMC D-Max Dually Denali 3500HD (Sold) 2018 GMC D-Max Dually Denali 3500HD (Sold) 2020 D-Max Dually Denali on 33x12.50's 1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles |
04-05-2010, 10:06 PM | #3 |
Re: clutch fork
thanks. looks like I am missing the end of the rod and the spring. Mine is in the outside hole. Yours looks like the inside.
04-05-2010, 10:58 PM | #4 |
Re: clutch fork
I don't know if I put it in the inside hole or not. The Z-bar was hitting my headers, so I chopped it off and moved it over on the tube. I may have put it in the inside for better alignment. Unfortunatlely, I did it almost 20 years ago, so I don't remember the right hole (get your mind out of the gutter). You can also see that I welded some nuts on it as spacers to take up some slack in the clutch movement. You need the wedge and the long spring for sure. Then put it in the hole that lines up the best. Outside hole should give you less pedal pressure but more pedal travel, inside hole should give you less pedal travel and more pedal pressure. Jeff
