Old 04-06-2010, 04:30 AM   #1
SatisTraction
Talking is your transmission tail shaft centered between your frame rails? I need a favor! :)
I am doing a 6.0 swap and the engine looks to be very slightly crooked. the tranny tailshaft is about .5" to the drivers side.
can anyone pull a tape across their tranny tailshaft and see if it is centered between the frame rails?
thanks!!!!!!!!!!
WTB 73-87 SWB fleetside bed!!
85 C10 6.0 project
69 camaro ls1 / t56
90 mustang lx
75 bronco injected 351w
SatisTraction is offline   Reply With Quote
Old 04-06-2010, 10:03 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: is your transmission tail shaft centered between your frame rails? I need a favor
Anyone?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-06-2010, 02:32 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
I just looked and mine is centered. The engine mount stands and trans crossmember bolts have a little play if you need to adjust. Just take the frame stand bolts loose and shift the engine and trans where you need it to be and bolt them back down.
--Josh
Old 04-06-2010, 02:38 PM   #4
SatisTraction
thanks but yours is also a swap.
I am looking for a SBC one with oem type mounts. i jsut want to be 100% sure before i finish my mounts.
i think i found some long tubes that will work but i have to do a little more work to post up results.
85 C10 6.0 project
69 camaro ls1 / t56
90 mustang lx
Old 04-07-2010, 04:10 PM   #5
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Mine was centered pre-swap, and is again centered post-swap.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-07-2010, 04:35 PM   #6
78-5.3
78-5.3's Avatar
wouldnt make a differance if it was pre swap or lsx should be center!! mine is!!! what mounts do you have the slotted type???
78 C-10 5.3 LSX -4L60E
78-5.3 is offline   Reply With Quote
Old 04-07-2010, 06:23 PM   #7
SatisTraction
thanks. I assumed it was centered but that is not always the case.
My mounts may end up being totally custom. i want the engine set back as far as possible in the bay.
right now i have the carshops mounts and have made the engine stand mod but i am not satisfied with the fit. the more weight i can get to the back the better i will feel
85 C10 6.0 project
69 camaro ls1 / t56
90 mustang lx
Old 04-07-2010, 07:47 PM   #8
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
I made my own mounts, and Im pretty sure mines centered. I couldnt imagine why it would be angled unless somethings not right upfront...
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 04-07-2010, 08:41 PM   #9
cdowns
cdowns's Avatar
dont really matter if it's centered that's what ujoints are for// many many cars came off assembly lines with off centered drivetrains and many millions of miles down the road few people ever knew
Old 04-07-2010, 09:06 PM   #10
SatisTraction
LOL, that is right. many engines are not centered between the frame rails.
85 C10 6.0 project
69 camaro ls1 / t56
90 mustang lx
Old 04-07-2010, 09:34 PM   #11
STOCKISH
STOCKISH's Avatar
I know mine is a swap but I am using the factory mounts. Hope you get yours figured out.
--Josh
Old 04-07-2010, 09:39 PM   #12
bikes&bowties
bikes&bowties's Avatar
i dont think .5 will matter... for example I just went and checked out a guys new rock crawler he is building and its 4 wheel steer... the rear driveline sits at a crazy angle vertically and horrizontally so I wouldnt worry about it
bikes&bowties is offline   Reply With Quote
