Old 01-16-2001, 12:52 PM   #1
Old Dave
Is a bullfrog waterproof?
Old Dave's Avatar
Question Oil leak
I have an 86 suburban 1/2T 2WD that is leaking around the oil pan front & back. Sides are dry front to back. There is about 4 in. of clearance between the front of the pan and the crossmember. Will I have to raise the motor to replace the pan gasket? I'm going to use a 1pc. Felpro. I replaced the timing gear, chain and front oil seal about 75K ago. You can see where oil is leaking past the seal on the front of the pan. Any suggsetions??
"It is better to remain silent and be thought a fool, than to open one's mouth and remove all doubt."
Ben Franklin
1970 Chevy shortbed
2002 Harley Custom Chopper (Long sucker)
1998 K2500 5.7L 5-speed Longbed
1st two are My son's toys...they just live in my garage!
1997 GMC K1500 Suburban
1993 S-10 Blazer 4D (youngest son's daily driver)
2000 Dodge Ram 4WD Ext. Cab (5.9L)
Wife is a late year 1951
Old Dave is offline   Reply With Quote
Old 01-16-2001, 07:03 PM   #2
bigd65
bigd65's Avatar
Post
you should have plenty of room to remove the oil pan with out lifting the motor , i do on my 85 C10.
85 C10 350/700r4
HOLLEY STREET DOMINATOR IANTAKE
EDELBROCK 1406 COMP. SERIES CARB.
HYPERTECH POWER COIL
FACTORY HEADERS
MAGNAFLOW CAT/MUFFLER/3in. EXHAUST
3.42 REAR GEARS
PROTHANE SUSPENSION-TOTAL KIT
and still going
"thats my toy"
Jeff Dodson
Angleton,Tx.
2024 Silverado Z71 PPV
1972 Chevy Monte Carlo
2018 Buick Enclave (Wifes)
bigd65 is offline   Reply With Quote
