Old 04-06-2010, 10:07 AM   #1
rodstored-72
chevy truck fan
rodstored-72's Avatar
Question 1972 Cab Trim Removal
All,
I need to remove the cab trim piece(s) that is just below the rear window. I am not sure how to do this and keep it re-usable??
thanks!!
rodstored-72
rodstored-72 is offline   Reply With Quote
Old 04-06-2010, 11:32 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 1972 Cab Trim Removal
The trim is held on with small plastic clips. The last one I did I used a small screwdriver & the corner of a putty knife to pop the trim loose from the corner of the cab then slide it off of the other clips. If your paint is nice use a piece of cardboard under your tools. After you get the trim off the clips just slide the clips over and pull them off.
Here is a thread I posted that has some pics of the clips on it.
http://67-72chevytrucks.com/vboard/s...d.php?t=333478
LockDoc
Leon
Old 04-06-2010, 11:32 AM   #3
GruntMoanCough
GruntMoanCough's Avatar
Use something like a gasket scraper close to the plastic clip and kind of rock the molding to release it.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 04-06-2010, 12:45 PM   #4
rodstored-72
chevy truck fan
GUYS,
THANKS!! i will try to do these helpful hints tonight.... i will let y'all know how i do...
thanks again!!
