04-06-2010, 10:12 AM | #1 |
Active Member
watts link
hey! does anybody know the optimum angle of the watts link center at ride height? thanks-Mark
No vehicle is "too nice" or "too straight" to cut up. |
04-06-2010, 01:12 PM | #2 |
67cheby
Re: watts link
porterbuilt says they should be parallel at ride height, hopefully he is right because that how i set mine up, sorry messed up that first pic is fully dumped, i will try again
http://67-72chevytrucks.com/vboard/s...d.php?t=554172 Last edited by 67cheby; 04-06-2010 at 01:12 PM. |
04-06-2010, 01:14 PM | #3 |
67cheby
Re: watts link
here we go, this pic is at ride height
http://67-72chevytrucks.com/vboard/s...d.php?t=554172 Last edited by 67cheby; 04-06-2010 at 01:14 PM. |
04-06-2010, 01:51 PM | #4 |
Re: watts link
For best results the center piece should be straight up and down (or at least the mounting holes should be) and your bars should be parallel to the ground. That will put you dead in the center of the travel.
04-06-2010, 02:23 PM | #5 |
Active Member
Re: watts link
sweeet! thanks guys.. i was looking at other sites saying it needed to be at an angle at ride height.. straight it goes!
04-06-2010, 07:10 PM | #6 |
Re: watts link
My estimation is that the angle of the center link makes no difference on the horizontal load forces as long as the bars are mounted parallel at ride height and you have more then enough centered verticle change in height due to the geometry of the bar lengths and pivot locations.
Before you make it in metal, make it whith cardboard and thumbtacks so you can maximize your verticle straight line motion and minimize your bar length to your specific needs. |
