Active Member
Gauge Layout, your suggestions...
Just trying to get some feedback on the layout for the gauges, what do you all like what do you hate? Thanks.
"The Great State of Florida" |
Active Member
Re: Gauge Layout, your suggestions...
And a few more...
Personally, I like my gauges on the drivers side.
![]() (Sorry, Couldn't resist)
72 Cheyenne Super 1/2 LWB White/Dark Yellow 07 Avalanche 2LT 74 Sleek Craft Rebel Jet Boat W/Pontiac 400 Last edited by OhOneWS6; 04-06-2010 at 10:48 AM. |
Freddy I personally like pict#5 on post #1....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#5 for me also.
Never Ending Projects
Are you making your circle templates the hole size for the gauges or the actual out diameter of the bezel? Make sure it's the outer diameter as if you go by the cut hole size, you can run into clearance issues when you mount them.
Ask me how I know... ![]()
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
looks to me like your going to have so many gauges rhat they'll be so small you wont b seeing much of anything
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 04-06-2010 at 01:01 PM. |
I'd also take the steering wheel into account, If you can't see them while driving then there's no point... How about the regular setup with the dash pad that has three pods inserted?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
Old Duffer
![]() Join Date: Mar 2003
What gauges are you going to install? Electric or mechanical? If electric you may want to consider the placement with EMI as a potential problem. All that means is, an electrical signal from one gauge may interfere with the performance of another one. Even a "hot" wire passing behind a sensitive gauge could cause it to give a false reading.
'68 Short C20 Flatbed Dually w/ 292 4bbl, Langdon cast headers, and WC T5 trans. '81 G10 Shorty Van "Good judgement comes from experience, and a lot of that comes from bad judgement." Will Rogers "Under promise, then over achieve." |
slowest. build. ever.
![]() Join Date: Jan 2009
I like #1 on second post, also the last one.
the last one is sort of similar to what I've been wanting to do, minus a couple gauges. |
Factory Strippers Rule!
![]() Join Date: Mar 2009
You will feel like you're flying a plane with all those gauges.
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
Active Member
A lot of really good stuff to think about and work out before I start cutting.
1000 thank yous...
"The Great State of Florida" Last edited by KFreddy; 04-07-2010 at 12:31 AM. |
