Hedders?
the great debate.......i have a 402 bigblock....do i yank the stock manifolds and replace with hedders? do they really leak like everyones says? my mechanic is dead set against them
Re: Hedders?
I have headers on my 427.Use the Percy's XX carbon gaskets ,they don't leak
71' Custom 10 (ole blue)
71' Custom 10 (ole blue) GM Goodwrench 350 Turbo 350 Transmission |
C/10 CLUB MEMBER
![]() Join Date: Jul 2003
Re: Hedders?
im glad this post came up...are there any shorty type headers for these BB trucks?...im gonna be swapping my engine out soon and was considering headers...but I don't want full length style for clearance reasons.
-Ron- ![]() Last edited by OldSkool71; 04-06-2010 at 07:59 PM. |
Re: Hedders?
i got a 72 chevy 402 and i got full length at stock ride height and i got no problem with clearance.. you gotta cut some old exhaust pipe and weld the part the collector bolts to onto your existing exhaust pipe.. i got a set for about $160.. and mine dont leak and i used the gasket it came with.. i just got new bolts and ran a tap in the holes to clean them out.. if you got ac you gotta take your pump outta the way with the power steering pump since they bolt in the header bolts
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
Re: Hedders?
I've been racing for about 8 years. Never could find a gasket that would last. Several fellow racers and one ex-mechanic/dragracer/parts salesman told me to throw the gaskets away and use the gray hi-temp rigid silicone. Put a bead on it, then snug the bolts up until the silicone touches the heads, let it sit for a couple hours until it hardens up some. Then tighten up the bolts like you would normally. I've been doing this for the last 4 years with no problems. Haven't even lost any ET. Hope this helps.
Re: Hedders?
Headers are great if they are a high quality part. I have hooker super comps on my b.b. and have NO issues with fit and clearance....no gasket issues as well, again good parts, retorque them once in a while and forget about them.
