cam choices?
so i am having troubles maybe thinkin i have a flat lobe on my cam.. what would be a great cam and lifters to give me that loping sound where it cuts it off and makes it sound like dying and what not
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
#2 | |
Re: cam choices?
Are you aware that you can't "just replace" a bad cam and put it back together? The entire engine must be removed, stripped and cleaned. The particles from the "flat cam" and the mating lifter will have spread through everything. The oil filter cannot handle that kind of volume and will begin to by-pass.
If you just R&R the cam and lifters, it will fail again.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Re: cam choices?
well my theory is i have a bad rocker and a bent rod from mis timing.. so fix the head and maybe cam and lifters if thats the problem
#4 | |
Re: cam choices?
![]() I've never heard it described quite like that. I would recommend changing to a roller cam setup. Today's oils don't have the zinc content that flat tappet cams need. If you do go back with a flat tappet cam, be sure to use zinc additive. |
Re: cam choices?
Rebuild engine!!?? I had a 77 stepside back in HS with a bad cam. Replaced it and beat the you know what out if it for 4 years. Ran when i sold it.
Re: cam choices?
engine only has about 15,000 miles on it.. so its almost im thinking something just came loose.. but i think im running hydraulic lifters
Re: cam choices?
if i'm gonna change out a valvetrain......it will be full roller and on a truck it will be nothing but an RV grind. i want smooth idle, tons of vacuum for the brakes and awesome throttle response and max low end torque so i can enjoy it on the street. in a "car" not towing anything, something a bit more peaky would be fun!
