Old 02-07-2003, 10:40 AM   #1
Estanley
Estanley's Avatar
Vortec build up???????????????
Has anyone here built and entire Vortec? I've got an 87 (maybe) complete Vortec. How does it compare to a more conventional 4 bolt main 350. I'm thinking of doing a complete rebuild on it and putting it in my 72. I've already got the GM intake for it.
Estanley is offline   Reply With Quote
Old 02-07-2003, 10:57 AM   #2
Jesse 67 c-10
Jesse 67 c-10's Avatar
Vortechs came in 1996, before that was TBI. I know most newer sb have roller cams, not sure about 87 though. Should be pretty much the same as any sb out there, maybe a one peice rear main seal? other than that they are the same old 350. You could put vortech heads on it. I can't tell ya much else though.
Jesse
Edmonton, Alberta, 67 c-10, Long fleet, front disks, 5 lug rear end, 327 with Vortechs, edlbrock manifold, comp cams XE 256, 600cfm carb. Backed by a getrag 5 speed and 1 piece driveshaft.
1993 Dihatsu Hijet Jumbo cab 4x4, currently converting to battery electric power.
Jesse 67 c-10 is offline   Reply With Quote
Old 02-07-2003, 12:46 PM   #3
Estanley
Estanley's Avatar
I'm not sure on the year but it has a one piece rear main and has Vortec heads. It has a plastic timing chain cover. What year would it have to be to be a Vortec?
Old 02-07-2003, 12:51 PM   #4
Gene
Gene's Avatar
I believe Vortech 350's were made from 1996 to 1999 then they went to the different block 4.8 liters and 5.3 Vortecs. Some 1996 trucks had TBI though.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 02-07-2003, 01:26 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
And as far as I know, other than the lack of a mech. fuel pump boss, the new heads, and a roller cam...it should be pretty much a good 'ole small block.
