Old 04-07-2010, 10:31 AM   #1
dyno
dyno's Avatar
Cab aluminum wrap trim- Glue on or clip?
Hi,
I want to install the cab brushed aluminum wrap trim (goes under rear window) on my '85 K3500. I found a good one in a junkyard and was hoping I could glue it on instead of drilling new holes and mounting all the clips. Anyone done this? Also, I'm afraid I'll damage the trim removing it from the junkyard truck. Is it hard to remove the trim for the clips? Do you just pry and pop it off?
Thanks,
Dyno
"Built- not bought"
1958 GMC 150 4x4 in progress
1980 K20- Restored
1985 K3500 Flatbed
58 GMC 4x4 build thread:
http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675
dyno is offline   Reply With Quote
Old 04-07-2010, 02:47 PM   #2
snc4life
snc4life's Avatar
Re: Cab aluminum wrap trim- Glue on or clip?
i dont know about glueing it on but its easy to remove just take off the corner peices 3/8 nut on the back side you can reach in and find easy then slide the band off the clips i would not try to pry it off im sure that will damage it for sure the clips just pop off if you lift them up you can get it like that aswell i just rivited th clips on my truck when i did it worked out fine and i know its never coming off
sure bow ties are for little boys ....[B]but ponys are for little girls
snc4life is offline   Reply With Quote
Old 04-07-2010, 08:55 PM   #3
dyno
dyno's Avatar
Thanks. I will remove the one a the junkyard and see if I can silicone it on instead of glue. I hate drilling holes in my cab!!!
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 04-07-2010, 09:08 PM   #4
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
i have mine too i just got the old ones polished but i had all the holes filled and i dont want to open any new hole, i was thinking double sided tape to mount it back up.
staggerd86c-10 is offline   Reply With Quote
Old 04-07-2010, 09:20 PM   #5
Kalashnikov46
Kalashnikov46's Avatar
problem with the double sided tape is half the time it down work lol. silicon or rivets are good ideas. idk, just never had good luck with double sided tape.
Kalashnikov46 is offline   Reply With Quote
