Old 04-07-2010, 12:55 PM   #1
72TXSuperCheyenne
72TXSuperCheyenne's Avatar
72 C10 - need more power to wheels
Just purchased my first "classic." It is a 1972 C10 Super Cheyenne. Engine is a 350 CI, do not believe anything special in regard to heads, cams, inards etc.
It has a Edelbrock high rise intake. I upgraded to a new Edelbrock 600 with electric choke and put headers with 2 1/2 pipes to flow master mufflers.
It has a THM350 3 speed auto and looks like stock 12", 12 bolt rear end.
The engine runs and sounds GREAT. HOWEVER, instead of acceleration expected of a 250-270HP (?) engine, it accelrated like a YUGO at times.
What should i explore for immediate lower cost fixes? Planning on new drive train, 400HP crate engine, 700R4 tranny, and new rear end next year, so do not want to spend too much.
thanks
72TXSuperCheyenne is offline   Reply With Quote
Old 04-07-2010, 01:50 PM   #2
Rat Bastid
Rat Bastid's Avatar
Re: 72 C10 - need more power to wheels
retime it and make sure dizzy is tightened down!.......guessin it might be loose
Rat Bastid is offline   Reply With Quote
Old 04-07-2010, 01:56 PM   #3
72TXSuperCheyenne
Will give that a whirl. It's a HEI, but not high performance one. Maybe go with a better HEI?
Old 04-07-2010, 02:20 PM   #4
Rat Bastid
Rat Bastid's Avatar
i have hei also and my distributer was loose and lost major power
Old 04-07-2010, 02:42 PM   #5
1quik70
I have always run HEI, even on my BBC in the Nova, so i would check the time and make sure its tight. HEI's only weak point in stock form is about 6500 RPM, they tend to fall flat, that can be fixed with a simple module change. I would also do a leak down test, to see how well the rings and heads are sealing. That will cost you soo much power!!! I had a stockish 350 in my 70 CST LWB that had a 12bolt with 3:73's and it was OK but not a rocketship, I had the heads decked, and chagned the intake and carb, and it made a world of difference. The leakdown test will tell the tale, if all is well, you may opt for the crate motor for more power anyway. But it it checks out good, put a cam in to match the RPM range your intake calls for (off idle-5500) and have the heads gone through (>$500), you will most likely have more power thatn you will need. Now if your looking for a 12sec street truck we need to talk some more, but if you just want plenty of power to push these heavy truckls around, my recipe above works great!
1quik70 is offline   Reply With Quote
Old 04-07-2010, 06:13 PM   #6
72TXSuperCheyenne
Thanks 1quik. will let you know!
Old 04-07-2010, 06:39 PM   #7
72TXSuperCheyenne
Going to try a brand new MSD Street Fire HEI tomorrow.
Old 04-07-2010, 06:45 PM   #8
neba
a new dist will probably do nothing unless something is wrong with old dist. if you have a small yellow wire powering your dist it could be your problem.
neba is offline   Reply With Quote
Old 04-07-2010, 07:49 PM   #9
70cst
70cst's Avatar
Remember these are trucks so don't expect it to run like a muscle car. Good luck. Then again what do I know.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 04-07-2010, 08:01 PM   #10
mrh33916
Project '67 454
mrh33916's Avatar
Is the high rise intake a single or dual plane?
Dual plane intakes build more torque from idle which is what these heavy trucks like.
67 C-10 SWB Fleetside 454 (current project)
99 Crewcab SWB Dually 454
75 Datsun 280ZZ430
94 Formula 232LS 454
mrh33916 is offline   Reply With Quote
Old 04-07-2010, 08:04 PM   #11
1quik70
Your exactly right, expect it to be faster and hurt some peoples feelings!!! These trucks are heavy, but can be plenty quick. Do a YouTube search for " farm truck", it's a red 69 or 70 with a white topper. Watch a few clips of that one and come back and let me know what you think!
Old 04-08-2010, 11:31 AM   #12
72TXSuperCheyenne
I beleive the intake is Edelbrock Performer EPS dual plane manifold.
The feedback i am getting from my mechanic and parts guys is the HEI basic dizzy is not producing enough fire to burn the gas the Edelbrock 1406 600CFM is pumping in.
They both say the MSD Street Fire will do the trick at reasonable cost ($115).
Not looking for it to move like a SS Camaro until i spend some real money next year on the drive line. Just looking to make it respectful until them
Old 04-14-2010, 09:37 AM   #13
72TXSuperCheyenne
Update - thanks for the feedback. Got the new Street Fire distributer in, replaced the ac delco plugs (r44t to r43ts) and it's running MUCH better.
Still not a street rocket, but it get's out of it's own way now. thanks!!
Old 04-14-2010, 10:02 AM   #14
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Good looking truck!
Now you got that power problem fixed you need to work on the stance.
I would do a 4.5/6" static drop on that puppy myself.
Good luck on whatever direction you take it.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 04-14-2010, 01:00 PM   #15
'72customdeluxe
a couple of points, better ignition won't fix a rich condition, your engine only takes in as much air as it needs, and the factory carb is 750cfm... Your mechanic is wanting money
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 04-14-2010, 01:16 PM   #16
1quik70
Better ignition won't FIX a rich condition, but it helps burn the fuel that is there. Had the same issue in one of my big blocks, it would run great but ruin plugs, and I narrowed it down to the stock HEI stuff. Changed to MSD Pro Billet, and a 6AL, problem solved! That pickup should move ok, my LWB 70 would flat run with just a stock bottom end and a fresh top end ( cam, intake, and fresh heads). Keep tinkering with it, you'll figure things out!
Old 04-14-2010, 02:20 PM   #17
big_al_71
big_al_71's Avatar
Mine Does!!!!! and then some
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 04-14-2010, 05:37 PM   #18
72TXSuperCheyenne
going to get me one of those next year!! plus a 700r4, a new posi rear end, sme Boss 338's, and a lowering!!
Old 04-14-2010, 05:39 PM   #19
'72customdeluxe
sounds like a plan! I would substitute a 2004r for a 700r4 however
Old 04-15-2010, 11:04 AM   #20
72TXSuperCheyenne
C20-67- n MO, being new to all this (only had the truck 3 weeks), what would the 4.5/6 look like height wise?
I know you mean down 4.5" in front and 6.0" in rear.
have an example picture?
Once i get the money for the engine/tranny/rear, definetly will upgrade the suspension to withstand the increases power and was planning a lower stance, though not low-rider low.
72 customdelux - will definetly look at the 2004r as well. GOTZ to have O/D for my 7 miles highway drive each day.
thanks guys!
Old 04-15-2010, 11:10 AM   #21
Original67
thanks guys!
Do a thread search on lowered trucks. I know that there are some threads bouncing around of dropped trucks just a few weeks ago.
Original67 is offline   Reply With Quote
Old 04-15-2010, 11:15 AM   #22
Original67
Totally agree. beware of telling mechanics what you think is wrong. or what you think might fix it. They will work you over hard to get you to spend needless money. My guess there was a different issue that was resolved when you put the new one in. (Loose dis, bad timing, etc) becareful of assuming parts are bad before you check them. This will get you spending alot of money for no reason.
Glad your happy though.
Old 05-18-2010, 10:53 AM   #23
72TXSuperCheyenne
Re: 72 C10 - need more power to wheels -RESOLVED
UPDATE:
Major issue was the TH350 that was shot. About 2 1/2 weeks after my first post and 4 weeks after bought it sight unseen on Ebay it basically lost all gears.
Got to test drive it last night after the following major changes:
MSD Street Fire dizzy with 0 resistance street fire plug wires
1.5/1.6 EPWI roller rockers
K & N air filter and cover
700R4 rebuilt level 3 transmission
rear end inspection (3.73 posi in mint condition)
Transmission cooler
new hoses and belts all around
new fly wheel
3" off drive shaft, new yokes and u joints
new power steerting gear box
Needless to say, the 350 is not as mild as thought. Engine has come to life, great speed and power, the tires finally made some noise!
Can't wait to get it back on Friday!
