Old 04-07-2010, 01:19 PM   #1
68 C-10 Panel
68 C-10 Panel's Avatar
Question Push the button....lock pops up....WHY?
Well like the title says, the passenger door wont stay locked. If I push down the lock knob and shut the door, it pops up as it closes. The driver door does that as well. However even if you lock it with the key, you can push the button on the door handle and the lock pops up. I have not taken the door apart yet, so I thought I would see if anyone here has ever had the same thing. Thanks in advance.
68 C-10 Panel (fixing) 250-6,3ott
93 k1500 pickup DD
"When a man is old enough to figure out his dad was right, he has a son who thinks he's wrong" Charles Wadsworth
68 C-10 Panel is offline   Reply With Quote
Old 04-07-2010, 01:37 PM   #2
heavy70
heavy70's Avatar
Re: Push the button....lock pops up....WHY?
my truck has been that way from the factory, lock it with the key from the outside or lock it from the inside with the door shut, smart bc you wont ever lock your keys in the truck....
heavy70 is offline   Reply With Quote
Old 04-07-2010, 01:39 PM   #3
Gene
Gene's Avatar
Thats the way every one I have ever owned works, frustrating yes, but like the above poster said it keeps you from locking yourself out.
Gene is offline   Reply With Quote
Old 04-07-2010, 01:39 PM   #4
Trip59
Who needs sleep...
Trip59's Avatar
If it's locked and you push the button on the exterior handle it unlocks? Or did I just read that wrong. My 72, until I just shaved it, the only way to lock it was to use the key or press the knob inside, closing it after locking would unlock it.
Trip
Trip
72 GMC 1/2T LWB
Build and Project Blog: http://72.tripbauer.com/
Trip59 is offline   Reply With Quote
Old 04-07-2010, 01:59 PM   #5
michael bustamante
michael bustamante's Avatar
my 67 does that too. I hate it.
1967custom
michael bustamante is offline   Reply With Quote
Old 04-07-2010, 02:09 PM   #6
Southcity
Southcity's Avatar
That's they way it is with these trucks and many other vehicles from the 50's, 60's and early 70's but like the others here have already mentioned, it's a great preventative from locking your keys in the vehicle. But I too am confused by your statement wherein you say you lock the door from the outside with the key then depress the button on the door handle and the lock pop's up? I have never seen that happen unless the lock is not fully engaged/depressed when you lock it with your key from the outside.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 04-07-2010, 02:33 PM   #7
Trip59
Who needs sleep...
Trip59's Avatar
Hey, you could always do what I did and just remove the inside and outside handles... then you don't need the lock
To be honest, half the reason I did it was because I hated having to walk around to lock both doors or strain my back to reach the passenger door from the inside
Trip
Trip
72 GMC 1/2T LWB
Old 04-07-2010, 03:03 PM   #8
John Fabris
TOTY 2006
John Fabris's Avatar
Well, you are describing two different things.
For all 67-72 trucks, you have to lock the door with a key as it will pop up (unlock) when you shut the door.
Now, for the problem when your door is shut and locked and you push the button(outside) to open the door, it pops the lock up. this can be fixed by readjusting the stiker plate. What is happening is that your door is not shut all of the way and your lock is not properly locked. (most likely due to age and wear) Try moving your catch plate (on cab) outward towards the door just a tiny bit at a time to see if that helps.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 04-07-2010, 03:54 PM   #9
monte0185
monte0185's Avatar
Can you not hold the button in lock the door and while holding the button in shut the door? I dont really use door locks so i have never payed much attention to this.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 04-07-2010, 07:33 PM   #10
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Nope,
Its in the owners manual, only way to lock the doors are with the key, and from the inside. As stated above it helps you from locking up your keys, I actually like it......Never have to call a locksmith with these trucks.....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 04-07-2010, 07:40 PM   #11
Dynomutt
Dynomutt's Avatar
I've seen some do this when the door latch/lock mechanism is dry too. Might try hitting them with some lubricant/lithium grease.
MARQ
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=446194
Dynomutt is offline   Reply With Quote
Old 04-07-2010, 07:45 PM   #12
bbadfred
bbadfred
bbadfred's Avatar
My 72 and 67 both would stay locked if you hold the door button in after pushing the lock down and shutting the door. All my 50s and 60s chevys worked this way and also my 64 dodge. You guys are just too young LOL. Oh also my 70 chevy impala.
bbadfred is offline   Reply With Quote
Old 04-07-2010, 11:12 PM   #13
68 C-10 Panel
Ok thanks for the info. And yes I guess that I did describe two things. The only locking with the key is fine with me (shut the door lock pops up). But the "problem" is that the lock can be unlocked by pressing the door open button on the handle. I will move the door striker and see if that helps(thanks john). The P.O has had this poor truck all jacked up for the last few years and with alittle help and alot of work she will be as good as new. By the way... did I mention I love this board...never have come up short on help, even the small stuff. Thanks guys.
93 k1500 pickup DD
Old 04-08-2010, 12:32 AM   #14
John Fabris
TOTY 2006
No sweat, I was thinking that everyone else in this thread has ADD as they did not get the fact that you talked about after the door is shut and locked, and pressing the button unlockes the door.
John Fabris
67 C10 SWB
