Post Whore
![]() Join Date: Feb 2000
Rope gasket on transmission floor hump
When I pulled the transmission floor hump I found a rope type gasket that is completely oil soaked.
Is this a part that is available, or should I just buy some similar sized rope and use that?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
its all about the +6 inches
Call me a brute, but I just used some smurf goo on mine. (Silicone)
I just used the 3M black tar-like calk (sp?) strips my HVAC buddy gave me. I think they use it to seal up combustion chambers on forced air furnaces.
It was a bear to get to stick right but I wouldn't go without something to seal it up.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
rope gasket
Yukon Jack I've been kind of wonderiing about this myself as I am planning to switch my truck over to a standard trans with high hump. I looked at the factory assembly manual, and it isn't much help, although it does mention sealing compound (5/16"bead) for attaching the hump to the floor, I seem to remember someone on here mentioning how to do this some time ago. You should have your answer before sundown anyway. I'll be watching for this one too. lpaine
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart 1998 Chevy 1/2 ton ex cab V-6 5 speed 1967 Chevy SWB - project truck; not started just yet |
We glue the round rubber strip material like is used on the metal door panels using 3M trim Cement. Clamps are used to hold the rubber in place while it drys. Before installing we put the strip caulk in place,(3M) and install the hump.
Jim |
