Old 04-07-2010, 06:25 PM   #1
americanmuscle
are the 73-87 dash pads interchangeable?
I have an 84 truck and my dash is dry rotted to crap. I was planning on fiberglassing it and painting it but I like the shape of the 70's dash boards better. I have a friend who has a dash in better shape then mine out of a 75 truck he offered me and I was wondering if I refinished the 75 dash would it fit along with the vents still working?
thanks to anyone who can help.
Greg
Project "Abby"
84 swb 6.0 swap and rebuild.
http://67-72chevytrucks.com/vboard/s...d.php?t=395121
americanmuscle is offline   Reply With Quote
Old 04-07-2010, 06:32 PM   #2
Jonboy
Slots go on anything!
Re: are the 73-87 dash pads interchangeable?
Yes. It will fit just fine.
1974 Jimmy- 5.3/4L80e/NP241
Old 04-07-2010, 07:12 PM   #3
americanmuscle
sweet!i'll pick that sucker up tomorrow. do yuo know if I need to rod the vents or anything?
Project "Abby"
Old 04-07-2010, 07:40 PM   #4
flamingbig10
6.0 powered square
flamingbig10's Avatar
your vin tag will be covered, not all the dash clip will work and the bezel won't fit the greatest
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-07-2010, 09:52 PM   #5
USSkoval
'78-'80 pads do have the VIN opening.
USSkoval is offline   Reply With Quote
Old 04-07-2010, 10:22 PM   #6
flamingbig10
6.0 powered square
the vin move moved over a a little in 81 my 80 has a 81 dash and I can only see half of the vin
Aaron
Old 04-07-2010, 10:51 PM   #7
USSkoval
Hmm, didn't know that. I wonder why GM went to the trouble of moving it just a little bit.
Old 04-07-2010, 11:20 PM   #8
americanmuscle
well i'm planning on glassing it so I can always move it.
Project "Abby"
Old 04-08-2010, 03:08 AM   #9
Oldschool82
Balls to the wall!
Oldschool82's Avatar
I did the swap and I am using my 82' gauge bezel for now with the older style pad. It doesn't look to bad, but it would definitely look better with the matching year bezel...other than that...it fit on in there good with no problems or modifications . You can see in the pic, if you use the wrong bezel it will have a small gap between the top of the bezel and the pad. I just stuck a peace of rubber stripping in the gap to make it less noticeable for now.
1982 swb 1/2 ton
Also have a 2001, 400+ Hp T-top Camaro SS
Loving my old Chevy truck and my new square body family on here!Thanks for all the help,tips and ideas I have gotten already guys.
http://67-72chevytrucks.com/vboard/s...d.php?t=388836
............_________{\___
............l_(0),,,______(0)l
Oldschool82 is offline   Reply With Quote
Old 04-08-2010, 09:01 AM   #10
Jonboy
I forgot about the bezel being different. You can use an older bezel with a newer (81-up) dash pad and it will work fine; the later bezel does stick out with the older pad. 84 is the first year with the relocated headlamp switch and wipers on the column, too.
Old 04-08-2010, 11:42 AM   #11
americanmuscle
Thanks for all the help guys. Ill be sure to grap the bezel for the dash.
Oldschool82- I like the aluminum you put on the dash, I'm planning something similar with mine but will have different vent holes.
Project "Abby"
Old 04-08-2010, 02:35 PM   #12
americanmuscle
Double post
Project "Abby"
Old 04-09-2010, 02:15 AM   #13
Oldschool82
Balls to the wall!
Thanks...yea I just whipped that up in a hurry. I don't care for the way the vents look on it.
1982 swb 1/2 ton
