got my new wheels today
Well at least 3 of them. They are series 33 wheel vintiques, 15" x 8" with 4" backspacing and imo they look sweet. I have done disc brakes all the way around and have no problem with the rears. They fit good back there. The fronts also fit but there is about 1/4" clearance max with the outer tie rod end. I don't yet know whats going to happen when I got the front end on the ground. Is this going to work or is it too close? Do I need to look at going to a 15" x 7" on the front??? Here are some pictures:
![]() ![]() ![]() ![]() ![]() Last edited by chevroletrestoguy; 04-07-2010 at 07:43 PM. Reason: pictures |
![]() Join Date: Oct 2009
Re: got my new wheels today
I think you'll be good to go on the front. The distance between your wheel and spindle should never change.
1965 Shortbed stepside Chevrolet C-10 My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=409676 |
You'll prob need to use adhesive wheel weights vs. traditional clamp-on style weights.
I run 15's with the same clearance, and the weights on the inside don't hit, so you will be fine.
Changing the wheel width will not affect the distance to the steering knuckle; decreasing the back spacing does this.
Like others have said though you should have no issues. |
Thanks for the info. I wasn't sure if I needed to go another route on the front or not.
![]() Join Date: Aug 2008
They're gonna look good
I Just got my wheels today too!! I went with 15"x8" & 15"x7" large I.D. Rallys. Had to special order them from Early Wheel in CA. They come with a larger inside diameter to clear Calipers, tie rods, etc. They take a 15" tire but have the I.D. of a 16". Took about 4 weeks to get. They're Chrome with steel centers that I'm going to paint dark gray metallic and I have Disc Brake Caps to put on - Cant' wait to get on... will post pics when I get them mounted.
![]() Join Date: Jan 2010
like others said. distance shouldn't change and you should be fine
So what's you guys opinions on optimal tire size???
One day...
Cool! I like those!
#13 |
Resistance is Futile
Big as possible
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
