04-07-2010, 10:41 PM | #1 |
starter??
hello everyone its been a long tome since ive been on here, been busy and finally picked up my 72 sb 350 and changed the plugs in it and cleaned up the outside. question tho the guy i bought it from said that the starter gets overheated from the ramhorn headers and it the engines warm it wont start. im very new to this truck and was wondering the right starter to get. that wont be the same problem. if the oem starter is the prob then ill just change it out with a replacement. he said theres a certain starter that fixes this problem but also said its expensive. then again this guy said i needed to junk the quadrajet. so help me out, thanks
04-09-2010, 10:57 AM | #2 |
Re: starter??
Put a Ford solenoid in place of the junction on the pass. fender. Run jumper from large terminal to small on Chevy starter. Run large batt. cable to Ford solenoid then to starter. Original wire that went to start term. on Chevy starter (jumpered now) will go to "S" terminal on ford solenoid - may need to be lengthened. Attach remaining wires from original junction to batt side of Ford solenoid (large terminal). This mod should eliminate any heat soak no-start issues.
04-09-2010, 11:04 AM | #3 |
Re: starter??
small hitorque is the way i go// if the starter is already having the heat soak problem chances of remote solenoid fixin it are slim
04-09-2010, 11:12 AM | #4 |
Champagne Taste on Beer Budget
Re: starter??
Wouldn't a heat shield help some of those problems?
Something to look into I would think.....
Coming Soon: Project 1970 Country Truck |
04-09-2010, 11:15 AM | #5 |
Between Trucks...
Re: starter??
I had a heat soak problem from running headers, remote solenoid was the cure.
Beat it to fit, Paint it to match... |
04-09-2010, 11:41 AM | #6 | ||
"I ain't nobody, dork."
Re: starter??
Hmm... this same thread was also started uin the "engine" section...
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
04-09-2010, 11:52 AM | #7 |
Re: starter??
A heat shield helps but I would say pull the starter off and replace the bushings and brushes in it for around ten bucks at Napa and go again.
90% of the hot start problems with these starters is because the bushings are worn enough so that the armature drags on the fields when the starter is hot. The Ford solenoid fix is also a good one that has been done for years and can easily be done by just about anyone by using a Ford solenoid, extra length of battery cable and a copper strip (made from a piece of flattened copper tubing). I'm not a fan of the "high torque" starters. On each and every board I am on there are several threads on the issues with them. The biggest issue seems to be that some of them are hard to get meshed up with the ring gear correctly. Also if the battery is a bit on the wimpy side you might have hot start issues so make sure that the battery is up to the task. New rigs with all new pieces and wiring can usually get by with any battery that fits in the space but older rigs tend to need all the oomph they can get in the battery department. And it still goes back to checking the basics Check each and every connection on the positive and ground cables. Check the condition of the cables Make sure that every other connection in the system is good and all of the wiring is in good shape. Check for patches in the wiring and things like butt connectors that may be causing resistance or suspect connections. On the QJet, If they are in good shape and set up right they are hard to beat for every day driving. You do either have to have the patience to go step by step when rebuilding your own along with a gentle touch or find someone who is good at rebuilding them. One issue with a lot of them is that the base plate wears where the throttle shafts go through allowing the shafts to be loose and or vacuum leaks in that area but usually there is someone around most areas that can do the repair or I would think that there is someone here on the board who is setup to rebush the holes and properly fit the shafts. The other issue is that the plugs in the bottom of the body sometimes leak but there are fixes for that including a piece that comes in every kit that you put in the base plate to seal things off. |
04-09-2010, 11:54 AM | #8 |
Re: starter??
Problem solved:
04-09-2010, 09:14 PM | #9 |
Junior Member
Re: starter??
I am putting a mini starter from a 1995 Chevy with a 350 on my 454 with heat soak problems as soon as I get the starter repaired.
Also I am going to install the remote solenoid just in case since I have one. I will probably also wrap the starter with a insulating blanket. I figure since I have to remove the header to take the old starter off might as well do everything, lol. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
04-09-2010, 09:37 PM | #10 |
Re: starter??
I remember something about using the Solenoid from a GM Diesel Starter from around 1980 when the General made an Olds gas motor into thier version of a car Diesel. Anyone? Al W.
