Old 04-07-2010, 11:11 PM   #1
sourkraut
sourkraut's Avatar
power steering question/problem
the think i am having trouble with is when i go lock to lock it has 1" to go on the pass side but the gearbox runs out of movement and can go/push past lock on driverside. do i have my pitman arm not in the right position on the gearbox spline? i thought i had it centered but must not have? if i am thinking correctly it goes in 1/4 incriments on the spline and am not sure if i just need to move it 1/4 turn in the correct direction so that it has the same distance? let me know what you guys think or if anyone ele has ran into this.
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
