![]() Join Date: Feb 2009
Gas Tank in frame
I bought a special built tank from TEBOW in Florida to go in the 62 C-10 frame and it is 10" deep by 8" and I am a little confused by the different hook ups. I looked up sending units at Summit Racing and others and they seem to match the hole on the top of the tank. I also have a threaded hole in the bottom front for a fuel fitting. The sending units I have looked at seem to draw the gas from the top of the sending unit and a 3/8 tube. What is the hole in the bottom for if the fuel is drawn from the sending unit. Or is there a sending unit that is for the gage only and the engine fuel pump just draws it straight from the hole in the bottom front.
I hope I am being clear with my question. Also does anyone recommend a sending unit for my application. Thanks. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Gas Tank in frame
I'm not familar with that brand of tank, but most aftermarket tanks like that use a sending unit that doesnot have the integrated fuel pickup line In which case you would use either a port that is low on the tank, or one on the top only if it has a pickup tube going to the bottom. If you could post a pic of the tank we might be able to help better.
Perhaps the one on the bottom is a drain?
I was always told you never want a bottom mounted fuel pickup on a street driven vehicle 'cause it will suck any dirt into the fuel line. A bottom drain on a fuel tank could prove to be very handy |
"I bought a special built tank from TEBOW in Florida"
That guy really DOES do EVERYTHING!!!! ![]() |
![]() Join Date: Sep 2006
pictures might help...
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#6 | |
It's Better With Nitro
1969 short box
this might be what you are looking for http://www.summitracing.com/parts/ATM-3262/
I'm just glad to be here!
It sounds like your tank is set up for a sending unit like the one tommy posted in the summit link and the fitting in the bottom is the actual fuel feed to the pump.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
I think the one that has been listed from summit fits the bill. I would assume that it is suitable for the 10" depth. I am also assuming that it sits on the bottom and measures the resistance as it uses fuel or adds fuel.
Thanks for the help. |
